For a finished project, what are you using to connect modules? RJ-45, serial cables?
It depends. Side by side, I still use right angle headers sometimes, if I have control over the pin order on at least one side(i.e. I'm making a board), and the number of reconnects is expected to be low. Field connections, usually RJ45/RJ12/RJ11. Connections carrying power or mixed power and signal, often I'll use a screw terminal set. I have boxes of 9/25/37 pin D connectors, but somehow I never quite get around to using them.
Those D-Sub are a bit bulky. But I found out that one variant with solder cups that the pcb can be forced in between the two rows of the connector. No THT but doublesided SMD ![]()
Yep. I've used them that way. It works, though desoldering was another matter.
