Cache or pre-compile libraries and cores
I'm trying to optimize my CI pipeline for some Arduino libraries I maintain. I have over 80 examples that I'd like to compile for a handful different target boards and architectures each. In total, there are around 600 sketch/board combinations, so compiling all of them takes quite a bit of time.
Right now, I'm using the arduino-builder, but I'm planning to upgrade to the arduino-cli.
What I'm looking for is a way to compile the core and the libraries only once for each target. Compiling and re-using the core seems to be possible using the --build-cache-path option, but I can't seem to find a similar option for third-party libraries.
Is this at all possible using the arduino-cli?
Would it make sense to modify the library.properties of the libraries in question to include the precompiled option, and compile the libraries manually in advance?
Thanks,
Pieter
PieterP:
Once ever, or once per CI run?
pert:
The main library under test once per CI run, but I might cache some third-party libraries or cores until I manually upgrade them to a new version.
Here's the GitHub Actions configuration I'm using: Control-Surface/examples.yaml at new-input · tttapa/Control-Surface · GitHub
It uses the following python script to run arduino-cli compile for multiple examples in parallel: Control-Surface/arduino-example-builder.py at new-input · tttapa/Control-Surface · GitHub
I've cached the ~/.arduino15 folder so I don't have to install the cores each time, and the /tmp/arduino-sketch-* folders in the hope that it would speed up compilation, but the effect of the latter is almost not noticeable.
You can find a run of this Action here: Add methods to enable/disable display elements · tttapa/Control-Surface@d31b950 · GitHub
As you can see, compiling 66 examples for AVR takes 5m39s (~11s/example), while compiling 63 of these examples for Nano 33 BLE (mbed) takes over 45 minutes (~1m30s/example)!
Any ideas how to speed this up?
