i think of the following project:
create a cadence like sensor only with counting e.g. magnet moving on a fitness device like stepper in front of a reed contact or hall sensor which is attached to a arduino.
the arduino needs to send it via bluetooth to the oculus quest (like other cadence sensors are doing) and can then be used dor fitness apps where you are vietually moving through space...
question: is there any available library / examples from this bt protocol?
in the end it should work with
But independet of a cyclic movement (stepper only have up and down)
thnx
cheese
