Hello everyone,
I am new in working with sensor and arduino. I just got an ambient light sensor DFR0026 with following specification.
- Detects ambient light density
- Works with Cds Photoresistor
- Analog voltage output: 0 to 5 Vdc
- Illumination range : 1 Lux to 6000 Lux
- Responsive time : 15us
- Suitable supply voltage: +3 to 5Vdc
- Interface with microcontrollers and logic circuits
- Standard 3-pin PCB connector
- Uses PH 2.0 socket
Since the analog output is in the range from 0-1023, and the Illumination range : 1 Lux to 6000 Lux. I use formula to calculate lux value of sensor as:
lux = analogRead *5999/1023
However the result returns around 1100- 1500 lux for normal indoor light which are wrong since the sensor app in mobile returns only around 110-120 lux.
What could be the problem in my conversion and how to fix it?
Thank you so much for your help.
