Calculate result in between multiple pre-defined point
Hi! I'm Thomas.
I did my own video light based on Arduino ESP32.
Question :
the light has Color temperature range from 2800-6500K
LED arrangement has 5 Colors
R/G/B/WW/CW
I calibrated the light using spectrometer and got some parameters that I have to use in code.
for EX. R11 G800 B455 WW1023 CW600 (10 bit 1024 levels)
BUT!! if let say I use 2800/4100/5500/6500 or more then it's static preset to choose.
My adjustment will resulting in 2800-6500 range from knob.
Is it possible to calculate something between calibrated point I made like I set it to 3500K then it calculate R/G/B/WW/CW based on 2 closest setting of 2800 and 4100.
Many Thx!!!
A standard approach would be to make table entries for several fixed color temperatures in the range 2800-6500 K and linearly interpolate between the table values. Much more detail here.
jremington:
I searched for example but still not lucky. Could you please provide such sample code or a link?
Example for what?
Post your code, using code tags, and forum members can help fix problems that have come up.
stefankante:
Maybe the map function is what you're after?
dougp:
Yes, I just found out "MultiMap" fit my need!!! Thanks for reply. Work like charm.
