calculate XOR checksum over multiple datatypes
Hi!
I've written a sketch which outputs a NMEA GPS-phrase every second. I need to calculate the XOR-checksum over all the transmitted bytes and add that as a 2-digit hexadecimal value in the end.
I've done this plenty of times with a character array, but now I'm constructing the output from a few different sources.
Serial.write(stream[0]);
Serial.write(0x32);
Serial.write(0x03);
Serial.write(0x02);
Serial.write(0x24);
Serial.print("PKLDS,,A,");
if(LatDegrees<10){Serial.print('0');}
Serial.print(LatDegrees);
if(dblLat<10){Serial.print('0');}
Serial.print(dblLat,4);
Serial.print(',');
Serial.print(NZ);
Serial.print(',');
if(LongDegrees<100){if(LongDegrees<10){Serial.print("00");} else { Serial.print("0");}}
Serial.print(LongDegrees);
if(dblLong<10){Serial.print('0');}
Serial.print(dblLong,4);
Serial.print(',');
Serial.print(EW);
Serial.print(",,,,,E00,100,");
Serial.print(VehicleID);
Serial.println(",80,00,*");
As you can see, the output is constructed of fixed values (',' - '0' ,..), chars (NZ - EW which hold the letter N S E or W), integers (LongDegrees) and doubles (dblLat,..).
I know this is not an example of good programming, but until now it seemed to do the trick. Obviously it's going to be a pain in the ass to calculate the XOR over all the bytes (almost 70 of them), as all output is in ASCII.
I was wondering if there exists a function that I can use just like Serial.print(), that constructs a char array of all the bytes, just as they would have been printed to the serial port? That way I could just run the entire thing through the XOR procedure and print to the serial port directly out of the array.
Thanks a lot!
sprintf() can. Actually, it doesn't construct the char array. You have to do that. What it does is populate the array.
