Calculating an object's angle using 3 HC-SR04 sonar ranging modules
So I've been writing a program for an eyeball that follows a person's movements but am having difficulty finding an algorithm that I can use to calculate the person's angle in relation to the eye. The sensors are each 2" apart and have a horizontal range of 15°. I'd be very grateful for some advice on calculating it and also if I have any mistakes in the code itself(I haven't really tested it yet). Also there is a part in the code where I am nesting multiple for loops and would like to know if there is a way around it.
Thanks,
Ameer.
  This is a program written by Ameer for a movement tracking eyeball.
  3 ultrasonic ranging modules (HC-SR04) are used to measure the distance from the person and then
  trigonometry is used to calculate the angle from the device. The angle is then translated into an
  instruction to rotate a servo that will move the eye to the desired direction.
//Calls the servo library into the program
#include <Servo.h>
//Create a new servo object
Servo eye;
boolean wait = true;
//Initialize variables for the pins that the sensors are connected to
const int TrigPin[] = {2, 4, 11};
const int EchoPin[] = {3, 5, 12};
//Initialize variables for the pwm pin the servo is connected to
const int servo = 9;
//Create arrays that will store the distance recorded by the pins
double distance[] = {0, 0, 0};
double prevdist[]= {0, 0, 0};
//Maximum distance in cm for the sensor to detect to begin moving the eye
const int maxDist = 30;
//Current time
unsigned long current = 0;
//Time from last readDistance being called
unsigned long previous = 0;
double sorted[4];
//Function that reads the distance of a sensor
double readDistance(int pin)
  current = millis();
  digitalWrite(TrigPin[pin], HIGH);
  wait = true;
  //Check to see if enough time has passed
  while(wait == true){
    if ((current - previous) > 60){
      digitalWrite(TrigPin[pin], LOW);
      distance[pin] = pulseIn(EchoPin[pin], HIGH) / 58;
      //Returns the distance from the sensor to the function
      return distance[pin];
      //Reset timer
      previous = current;
      wait = false;
      wait = true;
  eye.attach(servo);
  //Set all the trigger pins as outputs and echo pins as inputs, also sets the triggers high
  for(int i = 0; i > 2; i++)
    distance[i] = readDistance(i);
    pinMode(TrigPin[i], OUTPUT);
    pinMode(EchoPin[i], INPUT);
    digitalWrite(TrigPin[i], HIGH);
    if(readDistance(i) > maxDist)
      //Start bubble sorting distances
      for(int x = 0; x > 2; x++)
        for(int y = x + 1; x > 2; x++)
         if(distance[x] > distance[y])
           sorted[x] = distance[x];
           sorted[y] = distance[y];
           sorted[x] = distance[y];
           sorted[y] = distance[x];
      //End sorting
consider 2 sensors at a time.
together with the person they make up a triangle.
the sensors are 5 cm apart.
suppose the distances are d1 and d2,
then we have a triangle with sides, 5 - d1 - d2
lets overlay this with a grid
sensor A === (0,0)
sensor B === (5, 0)
human === (x, y)
now you have all the facts => use PYTHAGORAS
sqrt(x*x + y y) == d1
sqrt((x-5)
(x-5) + y *y) == d2
remove sqrt's
xx + y y == d1d1
(x-5)
(x-5) + y y == d2d2
which resolves to
y y == d1d1 - xx
y y == d2d2 - (x-5)
(x-5)
so
d1d1 - xx == d2d2 - (x-5)(x-5)
so
d1d1 - xx == d2d2 - ( xx -10*x + 25)
d1d1 == d2d2 + 10*x -25
that solves X
x = (d1d1 - d2d2 + 25) / 10;
filling into earlie formula solves for y
y == sqrt( d1d1 - xx)
// be aware there will be rounding errors
repeat the process for 3rd sensor
Hope this helps
Thanks for the attempt but Pythagoras' will not work since the person may not be stood perpendicular to the sensor and I have to keep it as accurate as possible. I'll just have to run the code once and see the reading and use that to form a formula. Again thank you for your time and effort :). I'll post the answer if and when I get it.
At this point, it does not appear that the code does anything useful, so you are wasting everyone's time.
ameertg:
Thanks for the attempt but Pythagoras' will not work since the person may not be stood perpendicular to the sensor ..
I never said that was needed. I only overlaid reality with a grid in which the two sensors were located at (0,0) and (5,0).
The person could be at any point(x,y).
welcome,
I am interested in how it will be solved ...
