Calculating average/mean of different type arrays with one function?
I have a few arrays, some of them are float some of them az int (uint16_t, analog readings). I would like to write a method that can calsulate the mean value of all of them. Here is what I got right know. The problem is that the function can't receive arrays with non floats.
#define NUM_OF_READINGS 5
uint16_t array1[NUM_OF_READINGS] = {1,2,3,4,5};
float array2[NUM_OF_READINGS] = {1,2,3,4,5};
uint16_t avg1;
float avg2;
  avg1 = average(array1);
  avg2 = average(array2);
  Serial.println(avg1);
  Serial.println(avg2);
float average (float *array) {
  float sum = 0L ;
  for (int i = 0 ; i < NUM_OF_READINGS ; i++){
    sum += array [i] ;
  return  ((float) sum) / NUM_OF_READINGS ;
Can I modify somehow the function, or do I need 2 functions for each types?
you could use a template
I aproached it a little bit different. Every arrays are float, but where it is needed, the average variable is integer, and I use tha "+0.5" trick to round the float from the function to int.
float array1[NUM_OF_READINGS] = {1,2,3,4,8};
float array2[NUM_OF_READINGS] = {1,2,3,4,8};
uint16_t avg1;
float avg2;
  avg1 = average(array1) + 0.5;
  float sum = 0L ;
    sum += array [i] ;
  return  ((float) sum) / NUM_OF_READINGS ;  // average will be fractional, so float may be appropriate.
