Calculating displacement using Accelerometer and Gyroscope (MPU6050)
Hi, I am a computer science student and working on an electronics project that requires to calculate yaw, pitch, roll and X,Y,Z displacement. I want to attach an IMU in a gun and track its orientation and displacement. I am able to get Yaw, Pitch and Roll but unfortunately cant understand how to calculate displacement or position of my gun. I am using a 10-DOF GY-87 sensor that contains MPU-6050.
I am getting values in term of g and m/s2 format. From the research that i have studied yet is that i need to get acceleration/time2 and then add all the values. But cant understand what time difference i should use.
Refrence: android - How to calculate distance based on phone acceleration - Stack Overflow
#include "I2Cdev.h"
#include "MPU6050.h"
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
// class default I2C address is 0x68
// specific I2C addresses may be passed as a parameter here
// AD0 low = 0x68 (default for InvenSense evaluation board)
// AD0 high = 0x69
MPU6050 accelgyro;
//MPU6050 accelgyro(0x69); // <-- use for AD0 high
int16_t ax, ay, az;
float dx, dy, dz = 0;
int16_t gx, gy, gz;
#define LED_PIN 13
bool blinkState = false;
    // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
    Serial.begin(38400);
    Serial.println("Initializing I2C devices...");
    accelgyro.initialize();
    Serial.println("Testing device connections...");
    Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
    Serial.println("Updating internal sensor offsets...");
    accelgyro.setXGyroOffset(85);
    accelgyro.setYGyroOffset(1);
    accelgyro.setZGyroOffset(-4);
    accelgyro.setXAccelOffset(-4269);
    accelgyro.setYAccelOffset(-4836);
    accelgyro.setZAccelOffset(1080);
    pinMode(LED_PIN, OUTPUT);
		accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
        dx=dx+(float)(((float)ax/(float)16384)*9.8*0.05*0.05);
        dy=dy+(float)(((float)ay/(float)16384)*9.8*0.05*0.05);
        dz=dz+(float)(((float)az/(float)16384)*9.8*0.05*0.05);
        Serial.print(dx); Serial.print("\t");
        Serial.print(dy); Serial.print("\t");
        Serial.print(dz); Serial.print("\t\n");
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
I want to track object as shown in the following youtube videos.
I would be grateful to you if anyone of you can guide me in this Regards.
Thank you
P.S: Sorry for my bad english and use of non-technical terms.
You can't use a consumer grade accelerometer to measure X,Y,Z positions with any accuracy; they are too noisy. Here is an explanation: http://www.chrobotics.com/library/accel-position-velocity
However, in some situations (like tossing a ball) you can roughly estimate the final trajectory from an initial large acceleration.
