Calculating epoch [Solved]
I’m trying to calculate a time in Unix format using the code below but, for some reasons, it’s not working. The code returns an incorrect date.
Any help is appreciated.
TIA
  //https://stackoverflow.com/questions/21975472/how-to-calculate-epoch-day
  // date march, 2, 2017 or 1488420000
  int tm_sec = 0;
  int tm_min = 0;
  int tm_hour = 2;
  int tm_yday = 61;
  int tm_year = 2017;
  int tz;
  tz = tm_sec + tm_min * 60 + tm_hour * 3600 + tm_yday * 86400 +
       (tm_year - 70) * 31536000 + ((tm_year - 69) / 4) * 86400 -
       ((tm_year - 1) / 100) * 86400 + ((tm_year + 299) / 400) * 86400;
  Serial.println(tz);
  // returns 1317108256 instead of 1488420000 for a date of 3/2/2017 2:0:0
I don't think 'int' is going to be big enough to hold tz.
@evanmars You're right. However, the change to unsigned int tz didn't help :confused:
unsigned long?
how about ulong?
no it didn't help either. I remind you that the code is returning a 10 digit number.
Unsigned long can hold 10 digits but only to 4,294,967,295. If you don't go too far in the future, you should be OK
@jbellavance it didn't help. perhaps the formula is wrong. I got it from here
ebolisa:
What do you get if you enter it into a calculator?
ebolisa:
int tm_sec = 0;
 int tm_min = 0;
 int tm_hour = 2;
 int tm_yday = 61;
 int tm_year = 2017;
Look again at the information in the link you provided.
For the year 2017, tm_year should be 2017 minus 1900, which equals 117.
The numbering for tm_yday counts January 1 as day 0. For your example date (March 2 of a non-leap year), we count 31 days from Jan. 1 to get to Feb. 1, then another 28 days to get to March 1, then finally 1 more day to get to March 2. We add up 31+28+1 to get 60, thus tm_yday should be 60 for March 2, 2017.
@odometer that was my error. Thank you much.
