Ok i didnt really want to share teh code as alot of it is irrelevant to the problem, however this part is within the function print_wave() and b1 can be assumed to be always high.
#include <Elegoo_GFX.h> // Core graphics library
#include <Elegoo_TFTLCD.h> // Hardware-specific library
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
const int b1 = 36;
const int b2 = 50;
const int b3 = 48;
const int b4 = 46;
const int b5 = 44;
const int b6 = 42;
const int b7 = 40;
const int b8 = 38;
const int f1 = 34;
const int f2 = 30;
Elegoo_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
void setup(void) {
pinMode(b1, INPUT);
pinMode(b2, INPUT);
pinMode(b3, INPUT);
pinMode(b4, INPUT);
pinMode(b5, INPUT);
pinMode(b6, INPUT);
pinMode(b7, INPUT);
pinMode(b8, INPUT);
pinMode(f1, INPUT);
pinMode(f2, OUTPUT);
Serial1.begin(115200);
Serial.println("boot");
tft.reset();
tft.begin(37697);
tft.setRotation(1);
tft.fillScreen(BLACK);
draw_text();
const uint16_t width = 320;
const uint8_t height = 240;
void loop(void){
//draw_grid();
if(digitalRead(b1)==HIGH)
print_wave();
void print_wave(){
uint8_t pixel_buffer[320][2];
uint16_t i = 0;
Serial1.flush();
while(digitalRead(b1)==HIGH){
i = 0;
digitalWrite(f2,HIGH);
while((digitalRead(f1)==LOW)&&(digitalRead(b1)==HIGH)){}
while((i<318)&&(digitalRead(b1)==HIGH)){
if((Serial1.available() > 0)&&(digitalRead(b1)==HIGH)){
pixel_buffer[i][2] = Serial1.read();
i++;
digitalWrite(f2,LOW);
uint8_t vmin = 0;
uint8_t vmax = 255;
if (vmax < pixel_buffer[i][2])
vmax = pixel_buffer[i][2];
if (vmin < pixel_buffer[i][2])
vmin = pixel_buffer[i][2];
i=1;
tft.drawFastVLine(i, 240-pixel_buffer[i][1]*0.7, 1, BLACK);
tft.drawFastVLine(i, 240-pixel_buffer[i][2]*0.7, 1, YELLOW);
pixel_buffer[i][1] = pixel_buffer[i][2];
i++;
i = 0;
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(RED);
tft.fillScreen(GREEN);
tft.fillScreen(BLUE);
return micros() - start;
void draw_text(){
tft.setTextColor(WHITE);
tft.setCursor(0, 0);
tft.setTextSize(1);
tft.println("Time div 10ms");
tft.setCursor(0, 10);
tft.setTextSize(1);
tft.println("Volt div 0.13V");
tft.setCursor(0, 20);
tft.setTextSize(1);
tft.println("Frequency 300Hz");
tft.setCursor(0, 30);
tft.setTextSize(1);
tft.println("Volt max 2.3V");
tft.setCursor(0, 40);
tft.setTextSize(1);
tft.println("Volt min 1.3V");
void draw_grid(){
tft.drawFastVLine(0, 60, height, RED);
tft.drawFastVLine(width-1, 60, height-40, RED);
for(int i = 1; i<10; i++){tft.drawFastVLine(i*32, 60, height-40, RED);}
for(int i = 1; i<65; i++){tft.drawFastVLine(i*5, 60+90-3, 7, RED);}
for(int i = 1; i<36; i++){tft.drawFastHLine(160-3, i*5+60, 7, RED);}
tft.drawFastHLine(0,60, width, RED);
for(int i = 1; i<6; i++){ tft.drawFastHLine(0,60+i*30, width, RED);}
tft.drawFastHLine(0, height-1, width, RED);
