Calculating fuel efficiency on a 1970s car
However is also lists min flow or 1liter/minute which = 60 liters/hour. This will only cover the top 2/3 of the range required (estimated).
Also, be cautious of anything cheap being compatible with gasoline. Automotive gasoline is a nasty fluid containing a myriad of hydrocarbon components. The seals needed to survive are more costly than you might find in a cheap flow sensor.
