Calculating heading distance, and direction
I'm having an extremely difficult time getting heading calculations correctly.
For example: I have a rover with a current heading of 270 degrees I want it to face 100 degrees. How do I calculate -What is the shortest distance, in degrees, to get to 100? -Which direction should the rover turn to get to 100?
I know it should be very simple, but for some reason the math is really throwing me off.
First compute the difference of the two numbers (270-100 --> 170 degrees). Now subtract 360 from the largest number and do it again ((270-360)-100 --> -190 degrees). The smaller number in magnitude tells you how far apart they are in angle: 170 degrees.
To figure out the direction, figure out whether you need to add or subtract 170 degrees to get from your current angle to target angle: the answer tells you which way you have to turn. If you subtract you're going counter-clockwise, else clockwise.
-- The MegaRAM shield: add 128 kilobytes of external RAM to your Arduino Mega/Mega2560
OK!
It had me stumped for a bit as well!
Mainly headings around due north, 0/360 degrees.
Thanks for the help!
But it doesn't quite work.
Check out this example Init Heading: 5 Target Heading: 355
num1=355-5=350 num2=5-360=-355-355=-710
350 is selected as our distance
350+5= 355, so we go clockwise.
When infact, to get to 355 from 5, we should be going counterclockwise 10 degrees.
Any ideas?
TarlSS:
I’m having an extremely difficult time getting heading calculations correctly.
This is quite simple once you realize that headings first need to be normalized to +/- 180 degrees (as opposed to 0-360). Shortest turn is then the normalized difference between the new and current heading. Direction to turn is left for a negative difference and right otherwise.
Example:
Current heading: 270 (normalized to -90)
New heading: 100 (normalized to 100)
Turn = 100 – (-90) = 190 (normalized to -170)
Shortest turn to reach 100 from 270 is then to turn 170 degrees left.
To convert from 0-360 to +/-180 can be done as follows:
While (heading > 180) heading -= 360
While (heading < - 180) heading += 360
Example: Current heading: 270 (normalized to -90) New heading: 100 (normalized to 100)
groan... OK, just stopped banging my head on the bench!
Thank you!
I am so glad for his forum!
I'll try that after my walk.
Note a turn left and a turn right together allways sum up to 360 degrees ( in flatland :wink:
That insight makes the code simple.
// assume new and heading are both 0..359 normalized (e.g. compass readings)
if (heading < new) heading += 360;  // denormalize ...
int left = heading - new;   // calculate left turn, will allways be 0..359
// take the smallest turn
if (left < 180)
  // Turn left : left degrees
  // Turn right : 360-left degrees
some samples
270 & 100
left = 270 - 100 = 170 => smaller than 180 so turn left 170
5 & 355
5< 355 => 5 → 365
left = 365 - 355 = 10 => smaller than 180 so turn left 10
5 & 10
5 < 10 => 365
left = 365 - 10 = 355 => larger than 180 so turn right (360-355)
270 & 10
left = 270 - 10 = 260 => larger than 180 so turn right (360-100)
Note a turn left and a turn right together allways sum up to 360 degrees ( in flatland smiley-wink
NO wonder I had problem, I live up here in dem hills!
It works now! I got heading hold of a sort!
Doing the rest of the chassis build now, finally got my second Pololu Motor controller!
Insert Quote Quote Note a turn left and a turn right together allways sum up to 360 degrees ( in flatland smiley-wink
In fact on the top of a hill the sum is less than 360 and down in a valley the sum is more than 360. It resembles the curved space equations of Einstein.
A thought experiment can make this clear:
Imagine you are on the top of a sphere (North pole) and you go 100 miles south* (call this place A). Turn 90 degrees and walk 2* PI * 100 miles East. You make a circle following a latitude line. In a flat land you would be on exact the same place A again. But because you are on a sphere this circle is a fraction shorter than its diameter (100 miles) suggests, so after 200 PI miles you will have passed place A. How many miles is left as an exercise ;)
  • if you are on the north pole the only possible heading is south ;)
yes!
and in the northern hemisphere going south is going up!
we're not "down under", we are on top!
:P
