I have an external device which sends binary data to my Arduino 16 bits at a time. Of these 16 bits, the first bit is even parity of next 7 bits while the last bit is odd parity for the previous 7 bits. I have an idea of how to do this in my head with a loop and a few conditionals but I don't quite understand how I would do this in Wiring. Can someone help me?
unsigned theValue; // 16-bit value from external device
// I'm assuming the "first bit" is the LSB and the "last bit" is the MSB
unsigned evenParity = (theValue & (1<<0)) ? 1 : 0;
unsigned oddParity = (theValue & (1<<15)) ? 1 : 0;
unsigned firstParity, secondParity, bit;
// Compute parity over first set of 7 bits past even parity bit
for (bit=1, firstParity=0; bit < 8; bit++) {
 firstParity ^= (theValue & (1<<bit)) ? 1 : 0;
// Compute parity over next set of 7 bits
for (bit=8, secondParity=0; bit < 15; bit++) {
 secondParity ^= (theValue & (1<<bit)) ? 1 : 0;
// Now do comparisons of firstParity vs. evenParity and secondParity vs. oddParity
Efficiencies can be realized in the above but hopefully this is more clear than efficient
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
unsigned char parity(unsigned long ino)
unsigned char noofones = 0;
while(ino != 0)
noofones++;
ino &= (ino-1); // the loop will execute once for each bit of ino set
/* if noofones is odd, least significant bit will be 1 */
return (noofones & 1);
That would be great but I can't seem to get that to work. I tried running 1111111 through parity_even_bit which should return true for even parity but it always returns false. Any ideas?
It says "returns 1 if val has an odd number of bits set."
Ie it returns a bit that you'd add to your transmission to make the whole thing be even parity...
