Calculating results in 0 (zero) (Solved)
Nothing special codewise I think?
If I declare all variables from long to float same result.
In the real code ValueIn is the only changing variable.
But the subsitute with a fixed figure for ValueIn does not give a correct value other then 0
If I calculate by calculator I get an other value then 0. >:(
What is the hickup?
I looked through some forum entries about calculating and Arduino but could not find the enlighting lines to solve the issue.
Any help in the right direction would be swell.
Paco
float LoadA;
float LoadB;
float ValueA;
float ValueB;
float ValueIn;
float ValueOut;
  Serial.println("Test");
  LoadA = 0;
  LoadB = 1229;
  ValueA = 282;
  ValueB = 4266;
  ValueIn = 1000;
  ValueOut = 0;
  //ValueOut = ((LoadB - LoadA) / (ValueB - ValueA)) * ((ValueIn) - ValueA) + LoadA // formula to calculate force with 2 know weight values 0 and 1229 grams
  ValueOut = ((1229 - 0) / (4266 - 282)) * ((1000) - 282) + 0;
  Serial.println(ValueOut);
  delay(100);
The integer calculation 1229/(4266-282) will be 0. If you want it done in floating point use decimal points:
1229.0/(4266.0 - 282.0)
Your arithmetic
is all integer.
Either cast to float, or express it as
ValueOut = ((1229.0 - 0) / (4266.0 - 282.0)) * ((1000.0) - 282.0) + 0;
Awol,
was the ticket.
Learned something today again.
Thanks both for quick quidance.
Paco
