I am trying to calculate RPM using a micros() timer every time the sensor returns 0.0, indicating one rotation has been completed. My code is printing out seemingly random numbers between ~30.0 and ~170.0 rpm. How can I fix my code to return correct RPM values?
Here is the code:
//*AMS Rotary Sensor AS5147
// Measures absolute angle position referenced at a set NORTH
#include <SPI.h>
// For TEENSY
#define CSN 9 // 10 Chip Select piN (CSN) pin which activates sensor
unsigned int angle;
float angle_value;
unsigned long startTime; //some global variables available anywhere in the program
unsigned long stopTime;
float rpm;
//Set Pin Modes
pinMode(CSN, OUTPUT);
digitalWrite(CSN, HIGH);
//Initialize SPI
SPI.begin();
startTime = micros();
angle_value = readAngleSensor(CSN);
//Serial.println(angle_value);
//Serial.println(startTime);
if (angle_value == 0.0){
stopTime = micros();
rpm = 1000000.0*60.0/(stopTime - startTime);
//Serial.println("start: "+String(startTime));
//Serial.println("stop: "+String(stopTime));
Serial.println(rpm);
float readAngleSensor(int chipSelect)
SPI.beginTransaction(SPISettings(10000000, MSBFIRST, SPI_MODE1));
//Send the Command Frame
digitalWrite(chipSelect, LOW);
delayMicroseconds(10);
SPI.transfer16(0xFFFF);
digitalWrite(chipSelect, HIGH);
angle = SPI.transfer16(0xC000);
SPI.endTransaction();
angle = (angle & (0x3FFF));
return (float(angle) * 360 / 16348);
Prints:
70.75
67.38
63.91
29.11
1428571.38
52.11
1463414.63
1428571.38
47.42
1428571.38
42.29
36.40
705882.38
1428571.38
705882.38
29.23
1428571.38
19.11
1428571.38
1428571.38
