Calculating the angle of two MPU6050 simultaneously
Hello!
I am looking for a way to measure angles with two MPU6050 on the same Adruino simultaneously. I attached the sketch that I am using.
MPU#1 works fine and I get really nice data. However, I get also a data output from MPU#2. The values are all around 134 and do not change when moving the MPU. Did I do anything wring with the calculation or with the wiring? ADO (0x69??) of MPU#2 is not connected to GND, but even connecting it with GND does not help.
I hope someone can help!
Inclination_with_two_MPU.ino (3.97 KB)
// WIRING OF THE HARDWARE
// Arduino - MPU1 - MPU2
// A4 - SDA1 - SDA2
// A5 - SCL1 - SCL2
// 3.3 - VCC1 - VCC2- ADO2
// GND - GND1 - GND2
#include<Wire.h>
const int MPU_addr=0x68;
const int MPU_addr1=0x69;
double AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
double AcX1,AcY1,AcZ1,Tmp1,GyX1,GyY1,GyZ1;
uint32_t timer;
double compAngleX, compAngleY;
double compAngleX1, compAngleY1;
#define degconvert 57.2957786
// Set up MPU 6050:
Wire.begin();
#if ARDUINO >= 157
Wire.setClock(400000UL); // Set I2C frequency to 400kHz
#else
TWBR = ((F_CPU / 400000UL) - 16) / 2; // Set I2C frequency to 400kHz
#endif
Wire.beginTransmission(MPU_addr);
Wire.beginTransmission(MPU_addr1);
Wire.write(0x6B);
Wire.write(0);
Wire.endTransmission(true);
Serial.println(“CLEARDATA”);
Serial.println(“LABEL, time, compAngleX, compAngleY, compAngleX1, compAngleY1”);
Serial.println(“Initializing I2C devices…”);
delay(100);
//setup starting angle
//1) collect the data
Wire.write(0x3B);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true);
Wire.requestFrom(MPU_addr1,14,true);
AcX=Wire.read()<<8|Wire.read();
AcY=Wire.read()<<8|Wire.read();
AcZ=Wire.read()<<8|Wire.read();
Tmp=Wire.read()<<8|Wire.read();
GyX=Wire.read()<<8|Wire.read();
GyY=Wire.read()<<8|Wire.read();
GyZ=Wire.read()<<8|Wire.read();
AcX1=Wire.read()<<8|Wire.read();
AcY1=Wire.read()<<8|Wire.read();
AcZ1=Wire.read()<<8|Wire.read();
Tmp1=Wire.read()<<8|Wire.read();
GyX1=Wire.read()<<8|Wire.read();
GyY1=Wire.read()<<8|Wire.read();
GyZ1=Wire.read()<<8|Wire.read();
double roll = atan2(AcY, AcZ)*degconvert;
double pitch = atan2(-AcX, AcZ)*degconvert;
double roll1 = atan2(AcY1, AcZ1)*degconvert;
double pitch1 = atan2(-AcX1, AcZ1)*degconvert;
double gyroXangle = roll;
double gyroYangle = pitch;
double compAngleX = roll;
double compAngleY = pitch;
double gyroXangle1 = roll1;
double gyroYangle1 = pitch1;
double compAngleX1 = roll1;
double compAngleY1 = pitch1;
//start a timer
timer = micros();
Wire.write(0x3B);
double dt = (double)(micros() - timer) / 1000000;
double dt1 = (double)(micros() - timer) / 1000000;
timer = micros();
double gyroXrate = GyX/131.0;
double gyroYrate = GyY/131.0;
double gyroXrate1 = GyX1/131.0;
double gyroYrate1 = GyY1/131.0;
compAngleX = 0.99 * (compAngleX + gyroXrate * dt) + 0.01 * roll;
compAngleY = 0.99 * (compAngleY + gyroYrate * dt) + 0.01 * pitch;
compAngleX1 = 0.99 * (compAngleX1 + gyroXrate1 * dt1) + 0.01 * roll1;
compAngleY1 = 0.99 * (compAngleY1 + gyroYrate1 * dt1) + 0.01 * pitch1;
Serial.print(“DATA, TIME,”); Serial.print (compAngleX, 4);
Serial.print(","); Serial.print (compAngleY, 4);
Serial.print(","); Serial.print (compAngleX1, 4);
Serial.print(","); Serial.println (compAngleY1, 4);
When using the I2C bus, you can read from only one device at a time: begin transmission, read and end transmission. Each device MUST have a unique address.
Sorry, but you should throw that code away and start over.
jremington: When using the I2C bus, you can read from only one device at a time: begin transmission, read and end transmission. Each device MUST have a unique address.
Could I do this with a delay-function between readings?
There is no reason to use delay. Read everything of interest from one device, then from the other.
How did you change the I2C address of the second MPU? Isn't the MPU I2C address read only?
The AD0 pin sets the low bit of the device address.
jremington:
I assume this is done by setting the MPU on 0x69:
#include<Wire.h>
No clue if it works!
Done! Separated the transmission of two devices as you said. Works well now. Thanks a lot for the help.
You [u]also[/u] have to connect AD0 on the second MPU to Vcc (not ground or floating).
treehugger: Done! Separated the transmission of two devices as you said. Works well now. Thanks a lot for the help.
Can i have the rectified code please?
