Calculating The Speed Of Sound with LM35 But It Always Says 0
I'm trying to calculate the speed of sound with LM35 sensor but it always says zero. Can anyone take a look at that code and tell me what is wrong?
const int sensor_pin = A0;
const int led = 10;
int sensor_deger = 0;
float sicaklik_deger = 0;
float voltaj_deger = 0;
float ses_hizi ;
float formul ;
  pinMode(led , OUTPUT);// put your setup code here, to run once:
  sensor_deger = analogRead(sensor_pin);
  Serial.print("okunan deger = ");
  Serial.println(sensor_deger); // put your main code here, to run repeatedly:
  voltaj_deger = (sensor_deger / 1023.0 ) * 5000 ;
  Serial.print("gelen voltaj = ");
  Serial.println(voltaj_deger);
  sicaklik_deger = voltaj_deger / 10;
  Serial.print("sicaklik = ");
  Serial.println(sicaklik_deger);
  float a = sqrt(1 + sicaklik_deger / 273);
  ses_hizi = 331 * a;
  Serial.println(ses_hizi);
  Serial.print("ses hizi = ");
  formul = 1/ses_hizi;
  Serial.print("formul = ");
  Serial.println(formul);
Here's the code. The formul has to give me the sound of speed with second/meter. But it calculates 0 every time.
Note: sensor_deger means sensor_value sicaklik_deger means temperature value voltaj_deger means voltage value ses_hizi means speed of sound with meter/second and formul means formul which supposed to give me speed of sound with second/meter
I forgot to translate I didn't wrote the code in english.
What do your prints tell you?
temp : 21.15 voltage : 241 speed of sound : 343.52 formul : 0.00
1/ 343.52 =?( to two decimal places)
1/343.52 = 0.00291103865 and then I will multiply by 100 to turn meter to centimeter and then I will divide it by 1000000 to turn second to microsecond so it should give me something like 29.11
But you’re only printing it to two decimal places.
I see no evidence of you multiplying this value by 100
But why does that give me only first two decimal places how can I print all the number?
Have you read the documentation for print/println? Maybe you should.
I just read that thanks.
