Calculating Tilt From Pitch and Roll angles From MPU-9250
#include <Wire.h>
#include <MPU9250.h>
#include <math.h>
// an MPU9250 object with the MPU-9250 sensor on I2C bus 0 with address 0x68
MPU9250 IMU(Wire,0x68);
int status;
float temperature;
int gyro_x, gyro_y, gyro_z;
long gyro_x_cal, gyro_y_cal, gyro_z_cal;
bool set_gyro_angles = false;
long acc_x, acc_y, acc_z, acc_total_vector;
float angle_roll_acc, angle_pitch_acc;
float angle_pitch, angle_roll;
int angle_pitch_buffer, angle_roll_buffer;
float angle_pitch_output, angle_roll_output;
long loop_timer;
int temp;
int dt = 800; //800 seconds
int lastCal = 0;
  Wire.begin();
  // serial to display data
  while(!Serial) {}
  // start communication with IMU
  status = IMU.begin();
    if (status < 0) {
      Serial.println("IMU initialization unsuccessful");
      Serial.println("Check IMU wiring or try cycling power");
      Serial.print("Status: ");
      Serial.println(status);
      while(1) {}
  // setting the accelerometer full scale range to +/-8G
  //IMU.setAccelRange(MPU9250::ACCEL_RANGE_8G);
  // setting the gyroscope full scale range to +/-500 deg/s
  //IMU.setGyroRange(MPU9250::GYRO_RANGE_500DPS);
  // setting DLPF bandwidth to 20 Hz
  //IMU.setDlpfBandwidth(MPU9250::DLPF_BANDWIDTH_20HZ);
  // setting SRD to 19 for a 50 Hz update rate
  //IMU.setSrd(19);
if (IMU.calibrateAccel() <= 0) {
    Serial.print("accelCal = ");
    Serial.println(IMU.calibrateAccel());
    } else if (IMU.calibrateAccel() > 0){
      Serial.print("OK accelCal = ");
  if (IMU.calibrateGyro() <= 0) {
    Serial.print("gyroCal = ");
    Serial.println(IMU.calibrateGyro());
    } else if (IMU.calibrateGyro() > 0){
      Serial.print("OK gyroCal = ");
 if (IMU.calibrateMag() <= 0) {
    Serial.print("magCal = ");
    Serial.println(IMU.calibrateMag());
    } else if (IMU.calibrateMag() > 0) {
     Serial.print("OK magCal = ");
 // read the sensor
IMU.readSensor();
IMU.calibrateAccel();
IMU.calibrateGyro();    //The 3 Types of Calibrations Inputs I found on Github for BolderFlight
IMU.calibrateMag();
temperature = IMU.getTemperature_C(),6;
for (int cal_int = 0; cal_int < 1000 ; cal_int ++){                  //Read the raw acc and gyro data from the MPU-6050 for 1000 times
    IMU.readSensor();
    gyro_x_cal += IMU.getGyroX_rads(),6;                                              //Add the gyro x offset to the gyro_x_cal variable
    gyro_y_cal += IMU.getGyroY_rads(),6;                                              //Add the gyro y offset to the gyro_y_cal variable
    gyro_z_cal += IMU.getGyroZ_rads(),6;                                              //Add the gyro z offset to the gyro_z_cal variable
    delay(3);
// divide by 1000 to get avarage offset
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
  loop_timer = micros();                                               //Reset the loop timer
//Subtract the offset values from the raw gyro values
  gyro_x -= IMU.getGyroX_rads(),6;
  gyro_y -= IMU.getGyroY_rads(),6;
  gyro_z -= IMU.getGyroZ_rads(),6;
//Gyro angle calculations . Note 0.0000611 = 1 / (250Hz x 65.5)
  angle_pitch += (IMU.getGyroX_rads(),6) * 0.0000611;                                   //Calculate the traveled pitch angle and add this to the angle_pitch variable
  angle_roll += (IMU.getGyroY_rads(),6) * 0.0000611;                                    //Calculate the traveled roll angle and add this to the angle_roll variable
  //0.000001066 = 0.0000611 * (3.142(PI) / 180degr) The Arduino sin function is in radians
  angle_pitch += angle_roll * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the roll angle to the pitch angel
  angle_roll -= angle_pitch * sin(gyro_z * 0.000001066);               //If the IMU has yawed transfer the pitch angle to the roll angel
  Serial.println(angle_pitch);
  Serial.println(angle_roll);
  //Accelerometer angle calculations
  acc_total_vector = sqrt((IMU.getAccelX_mss(),6*IMU.getAccelX_mss(),6)+(IMU.getAccelY_mss(),6*IMU.getAccelY_mss(),6)+(IMU.getAccelZ_mss(),6*IMU.getAccelZ_mss(),6));  //Calculate the total accelerometer vector
  //57.296 = 1 / (3.142 / 180) The Arduino asin function is in radians
  angle_pitch_acc = asin(((float)IMU.getAccelY_mss(),6)/acc_total_vector)* 57.296;       //Calculate the pitch angle
  angle_roll_acc = asin(((float)IMU.getAccelX_mss(),6)/acc_total_vector)* -57.296;       //Calculate the roll angle
  angle_pitch_acc -= 0.0;                                              //Accelerometer calibration value for pitch
  angle_roll_acc -= 0.0;                                               //Accelerometer calibration value for roll
  if(set_gyro_angles){                                                 //If the IMU is already started
    angle_pitch = angle_pitch * 0.9 + angle_pitch_acc * 0.1;     //Correct the drift of the gyro pitch angle with the accelerometer pitch angle
    angle_roll = angle_roll * 0.9 + angle_roll_acc * 0.1;        //Correct the drift of the gyro roll angle with the accelerometer roll angle
  else{        //At first start
    angle_pitch = angle_pitch_acc;                                     //Set the gyro pitch angle equal to the accelerometer pitch angle
    angle_roll = angle_roll_acc;                                       //Set the gyro roll angle equal to the accelerometer roll angle
    set_gyro_angles = true;                                            //Set the IMU started flag
  //To dampen the pitch and roll angles a complementary filter is used
  angle_pitch_output = angle_pitch_output * 0.9 + angle_pitch * 0.1;   //Take 90% of the output pitch value and add 10% of the raw pitch value
  angle_roll_output = angle_roll_output * 0.9 + angle_roll * 0.1;      //Take 90% of the output roll value and add 10% of the raw roll value
  Serial.print(" | Angle Pitch = "); Serial.println(angle_pitch_output);
  Serial.print(" | Angle Roll = "); Serial.println(angle_roll_output);
 while(micros() - loop_timer < 4000);                                 //Wait until the loop_timer reaches 4000us (250Hz) before starting the next loop
 loop_timer = micros();//Reset the loop timer
  //do {
  // display the data
  Serial.print(IMU.getAccelX_mss(),6);
  Serial.print(",");
  Serial.print(IMU.getAccelY_mss(),6);
  Serial.print(",");
  Serial.print(IMU.getAccelZ_mss(),6);
  Serial.print(",");
  Serial.print(IMU.getGyroX_rads(),6);
  Serial.print(",");
  Serial.print(IMU.getGyroY_rads(),6);
  Serial.print(",");
  Serial.print(IMU.getGyroZ_rads(),6);
  Serial.print(",");
  Serial.print(IMU.getMagX_uT(),6);
  Serial.print(",");
  Serial.print(IMU.getMagY_uT(),6);
  Serial.print(",");
  Serial.print(IMU.getMagZ_uT(),6);
  Serial.print(",");
  Serial.print("Temperature = ");
  Serial.println(temperature);
  //Serial.print(
  //}   while (IMU.calibrateAccel() >= 1, IMU.calibrateGyro() >= 1, IMU.calibrateMag() >= 1);
  //Remember to fix the lns for the functions you use.
  //Serial.print(theta);
  //Serial.print(",");
  //Serial.println(phi);
  delay(20);
I'm using a Eleggo Uno R3, and a Makerhawk MPU-9250 IMU.
I can't tell what the problem is with the code, or if it's a problem with IMU itself. Unfortunatly there have been issues getting the manufacturers code.
The pitch and roll go to 90 degrees and -90 degrees after starting from zero, and they stay there. I move the IMU around and tilt it, and they are always the same. I took the functions from other work on GitHub, so they must work. The accel, gyro, mag and temperature values change and seem to be working. Other than that is makes no sense that the pitch and roll are always these values even when lying flat.
Any help or suggestions would be greatly appreciated. Thank you.
Remove all of those ",6" and try again.
The ",6" means nothing outside of a Serial.print() argument list where, for a float value, specifies showing 6 places after the decimal point.
In particular, it is causing this:
    (IMU.getAccelX_mss(),6*IMU.getAccelX_mss(),6) +
    (IMU.getAccelY_mss(),6*IMU.getAccelY_mss(),6) +
to be parsed as:
acc_total_vector = sqrt((IMU.getAccelX_mss())+(IMU.getAccelY_mss())+(IMU.getAccelZ_mss()));
Instead of the sqrt() of the sum of the squares, your are getting the sqrt() of the sum.
The 'comma operator' in an expression means "evaluate the expression on the left of the comma and the expression on the right of the comma, but the result is the value of the expression on the left". In your expression, the stuff after the first comma has no side-effects so it's as if everything to the right of the comma was removed.
 // read the sensor
IMU.readSensor();
IMU.calibrateMag();
Why continuously calibrate the IMU parts?
Also, are you, during the mag calibration, moving the IMU in a figure 8 for every pass of the mag calibration? Otherwise the mag calibration, they way its being done, is poo.
Why do this
  gyro_x_cal /= 1000;
  gyro_y_cal /= 1000;
  gyro_z_cal /= 1000;
So you do know that rate gyros, like in the IMU you are using do NOT produce angles but, instead, produce rate of gyro precession?
That code does not cause IMU angle to be produced. Again, rete gyro's, like the one in the IMU you are using, do NOT give IMU angles, instead they produce a rate of precession. Rate of precession is NOT the same thing as an angle of tilt.
