calculating voltage and printing significant numbers to lcd
Hi all,
New project to be completed and documented and uploaded once completed but I have a slight problem when I want to print calculated voltage to my LCD here’s an example:
#include <LiquidCrystal.h>
LiquidCrystal lcd(27, 29, 31, 33, 35, 37);
float Voltage = 0;                // VALUE
int VoltagePin    = A15;           // VOLTAGE DIVIDER
lcd.begin(16,2);
 Voltage = analogRead(VoltagePin);
   Voltage = map(Voltage, 0, 1023, 0.00, 55.00);
lcd.clear();
     lcd.setCursor(0, 0);
      lcd.print(Voltage,2);
This is just a snippet of the code that I have written, what I need is to display voltage ie, 19.23 but all It will display is whole numbers, 16.00, 17.00 ect. I am using a simple voltage divider to step down 50-5v, I know it will not give a high degree of accuracy, even .1 degree will be fine.
Thanks, Neo
The map function takes all integer arguments. It returns an integer value.
When the from and to range start at the same point, division is much faster than a function call the performs subtraction and division.
Voltage = Voltage * 55.0 / 1023.0;
