Take the screenshot ...
Do I have to take the voltage drop into consideration?
Or is it always the voltage (before the forward voltage drop of the component...)
So to calculate led wattage...
5v × 0.595amp = wattage
NOT
5v - led fv - 0.6v diode drop...
Correct?
I think the question is mute. Aren't LEDs rated by current? ie, if the datasheet says it can handle 0.595 Amps then the wattage is irrelevant.
KenF:
Absolutely not... eg if you're told it's a 3watt LED.
3w/5v gives 0.6amps or 0.6×5v gives 3watts.
But add a transistor and other foward vf drops into the mix...
0.585 (5 - 2.93) = Wattage dissipation by LED
0.585 x 2.07 = 1.71 watts
It matters not what fancy components (correctly connected or otherwise) that are connected elsewhere in the circuit, it is simply the product of current-through and voltage-drop across the component that determines power "consumed" by it. As to the power emitted as light - that depends upon the chemistry of the diode but, obviously, can never be more than the power "consumed" (irrespective of what the manufacturer might claim)
jackrae:
0.585 (5 - 2.93) = Wattage dissipation by LED0.585 x 2.07 = 1.71 watts
It matters not what fancy components (correctly connected or otherwise) that are connected elsewhere in the circuit, it is simply the product of current-through and voltage-drop across the component that determines power dissipation across it.
And the forward voltage is pretty constant for a diode that's conducting. Hence my suggestion that it all comes down to current.
JohnLincoln:
I think you have the collector and emitter of the left hand transistor transposed in your simulation.
You only think it?
I am certain!
jackrae:
So why is it 700ma is classed as 3w?
Something don't add up...
OK...
Explain how an LED consuming 1000ma is '3 watt' lol
I think I may as well ignore wattage for LEDs.
cjdelphi:
I'm told that my engine has over a hundred horse power, yet when I calculate it's power when cruising down the road, I find it's producing much less.
.7A x 4V Vf = 2.8W. Still have to be concerned about cooling it.
The spec sheet says 700mA with a typical forward voltage of 3.5V. That's 2.45W.
It says it can be pulsed at 1000mA with a 25% duty cycle which is 3.5W (assuming approximately the same forward voltage).
So, I guess it's "approximately" 3W but it can't dissipate 3W continuously.
Well... We usually do need to know the approximate power we're dealing with... If I need to design a circuit for an LED, or if someone posts a question here about how to wire-up an LED, it's good to important to know if we are dealing with a normal-everyday ~40mW LED, or if we are in the 1W, 3W, 10W, or more range.
