Calculation of frequency
Hello everybody;
i found a scheme at arduino forums:
i will use this for resistance measurement.
but i cant figure out how to calculate frequency of oscillator depending on resistance.
is there a mathematical formula for this.
thank you
I had a flowmeter that had exact same output. it is likely to have a magnet to change the voltage (reed switch).
I used this to calculate the time. You can then divide 1/time to get frequency.
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the Serial Monitor.
Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
//unsigned long duration;
unsigned long timeOneLoop;
unsigned long timeStart;
unsigned long timeFinish;
int sensorValue;
float voltage=0;
float TotalFlow;
bool CountStarted=true;
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
//pinMode(A0, INPUT);
// the loop routine runs over and over again forever:
// print out the value you read:
//duration = pulseIn(A0, LOW);
//Calculate pulse
// read the input on analog pin 0:
sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
voltage = sensorValue * (5 / 1023.0);
//Serial.println(CountStarted);
if(voltage<1 && CountStarted) {
Serial.println("Started");
//Serial.println(millis());
timeOneLoop=millis();
CountStarted=false;}
else{
if(voltage>1 && CountStarted==false){
CountStarted=true;
timeOneLoop=millis()-timeOneLoop;
Serial.println("total time is:");
Serial.println(timeOneLoop);
TotalFlow = 10000.00/(timeOneLoop*4);
Serial.println("Total Flow is (L/Sec):");
Serial.println(TotalFlow);
delay(100);
The TLC272 doesn't have rail-to-rail outputs, so the oscillation frequency maybe less well defined
than the equations suggest as the rising exponential curve will intersect with the ill-defined
max output voltage (* 0.909)
Comparators are much more appropriate for this kind of relaxation oscillator, and the classic 555
is an example of this.
