i have a simular problem we're trying to make a flood alert but we dont know what to put as if xxxx>100
#include <LiquidCrystal.h>
// These constants won't change. They're used to give names to the pins used:
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int Buzzer = 9;
int Led = 10;
int Ledred= 8;
int Ledgreen = 7;
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int tones[] = {261, 277, 293, 311, 329, 349, 369, 392, 415, 440, 466, 493, 523 ,554};
// 1 2 3 4 5 6 7 8 9 10 11 12 13 14
// You can add more tones but i added 14. Just fill in what tone you would like to use, @ void loop you see " tone(Buzzer, tones[12]); " below, digitalWrite(Buzzer, HIGH);
// here you can change the tones by filling in a number between 1 and 14
lcd.begin(16, 2);
pinMode (Buzzer, OUTPUT);
pinMode (Led, OUTPUT);
pinMode (Ledred, OUTPUT);
pinMode (Ledgreen, OUTPUT);
// initialize serial communications at 9600 bps:
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 0, 255);
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the Serial Monitor:
Serial.print("sensor = ");
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
if (sensorValue >= 100()){
digitalWrite(Ledred, HIGH);
digitalWrite(Ledgreen, LOW);
digitalWrite(Led, HIGH);
tone(Buzzer, tones[6]);
delay(200);
digitalWrite(Led, LOW);
digitalWrite(Buzzer, LOW);
noTone(Buzzer);
delay(200);
tone(Buzzer, tones[14]);
delay(200);
noTone(Buzzer);
delay(200);
digitalWrite(Ledred, LOW);
digitalWrite(Ledgreen, HIGH);
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
