the formula is in the CALCULATE G-AXIS POSITION part
#include <math.h>
#include <Servo.h>
#include <SPI.h>
#include <SD.h>
//Konstanten
const int mainLength = 160;
const int secLength = 160;
const int armLength = 130;
//Z-Servo
Servo zServo;
Servo mainServo;
Servo mainServo2;
Servo gServo;
int zPos = 45;
int mainPos = 90;
int gPos = 5;
int zPosNow = 45;
int mainPosNow = 90;
int gPosNow = 5;
int zPosGoal = 45;
int mainPosGoal = 90;
float gPosGoal = 0; //------------------------------ <- Defining the Variable
int steps = 0;
//Koordinaten
String koordinaten = "";
char koords[50];
int gMode = 0;
int xCoord = 160;
int yCoord = 0;
int zCoord = 160;
int F = 100;
char delimiter[] = " ";
String line[] = "160 0 160";
int lines = 0;
//button
#define button 5
#define led 6
//SD KARTE
File dataFile;
String copyFile;
zServo.attach(2);
mainServo.attach(3);
gServo.attach(4);
mainServo2.attach(8);
Serial.println("Gebe die Zielpunktkoordinaten ein: (X Y Z Angriffswinkel");
zServo.write(map(zPosGoal,0,90,180,0));
mainServo.write(map(mainPosGoal,0,90,0,180));
mainServo2.write(map(mainPosGoal,0,90,180,0));
gServo.write(map(gPosGoal,0,90,0,180));
//SD KARTE
SD.begin(7);
sdRead(); //Read the File and Splits in
pinMode(button, INPUT);
pinMode(led, OUTPUT);
//###################################################### READ SERIAL MONITOR #####################################################
if (Serial.available() > 0) {
koordinaten = Serial.readString();
koordinaten.toCharArray(koords,50);
Serial.print("KOORDINATENEINGABE: ");
Serial.println(koords);
readLines();
zAxis(); //Call void to Caluclate Z-Axis
xAxis(); //Call void to Calculate Main-Axis
gAxis();
servoWrite(); //Move servos depending on steps
Serial.println("MOVED");
if (digitalRead(button) == HIGH) {
digitalWrite(led,HIGH);
Serial.print("ZEILEN: ");
Serial.println(lines);
callProgramm();
digitalWrite(led,LOW);
delay(100);
//##################################################### CALCULATE Z-AXIS POSITION ##################################################
void zAxis() {
float hypo = float(sqrt(sq(float(xCoord))+sq(float(yCoord))));
zPosGoal = 45+(asin((yCoord/hypo))*180/PI);
Serial.print("MOTORWINKEL: ");
Serial.println(zPosGoal);
steps = sqrt(sq(zPosGoal-zPosNow));
//zServo.write(map(zPos,0,90,180,0));
//##################################################### CALCULATE MAIN-AXIS POSITION ##################################################
void xAxis() {
float dist = float(sqrt(sq(float(xCoord))+sq(float(yCoord))));
float hypo = sqrt(sq(dist)+sq(float(zCoord)));
mainPosGoal = (acos((sq(mainLength)+sq(hypo)-sq(secLength))/(2*mainLength*hypo))*180/PI+asin(zCoord/hypo)*180/PI);
Serial.print("MAINWINKEL: ");
Serial.println(mainPosGoal);
int stp = sqrt(sq(mainPosGoal-mainPosNow));
if (stp > steps) {
steps = stp;
Serial.println("STEPS MAIN HIGHER THAN Z");
//mainServo.write(map(mainPos,0,90,0,180));
//##################################################### CALCULATE G-AXIS POSITION ##################################################
void gAxis() {
gPosGoal = (2*sq(160)-226.27*226.27)/(2*160*160); // ----------------- Here is the Formula.
//gPosGoal = sin(90*PI/180);
Serial.print("HYPO: ");
Serial.println(hypo);
Serial.print("G POS: ");
Serial.println(gPosGoal); //------------------ Here im printing it to Serial
int stp = sqrt(sq(gPosGoal-gPosNow));
if (stp > steps) {
steps = stp;
Serial.println("STEPS G HIGHER THAN Z");
//##################################################### WRITE SERVO POSITION ##################################################
void servoWrite() {
float zmove = float(zPosGoal-zPosNow)/steps;
float mainmove = float(mainPosGoal-mainPosNow)/steps;
float gmove = float(gPosGoal-gPosNow)/steps;
Serial.println(steps);
Serial.println(zmove);
Serial.println(mainmove);
Serial.println(gmove);
int i;
for(i = 0; i<steps; i++) {
zPos = zPosNow+i*zmove;
mainPos = mainPosNow+i*mainmove;
gPos = gPosNow+i*gmove;
mainServo2.write(map(mainPos,0,90,180,0));
gServo.write(map(gPos,0,90,0,180));
//Serial.print("ZPOS: ");
//Serial.println(zPos);
delay(10); //SPEED OF THE MOTORS (maybe 10 but to fast)
mainPosNow = mainPosGoal;
zPosNow = zPosGoal;
gPosNow = gPosGoal;
steps = 0;
//######################################################## SD CARD READ ################################################
void sdRead() {
dataFile = SD.open("Test.TXT",FILE_READ);
int i = 0;
while (true) {
line[i] = dataFile.readStringUntil('\n');
Serial.println(line[i]);
if (line[i] == "") {
i++;
lines ++;
void callProgramm() {
int i;
for(i = 0; i < lines; i++) {
koordinaten = line[i];
readLines();
gAxis();
Serial.print("LINE EXECUTED: ");
Serial.println(i+1);
delay(200);
//digitalWrite(led,LOW);
