'calibrateFader' was not declared in this scope
Hello Arduino comunity! I want to make a midi controlled motorized fader, I find a code on internet for it but it have some issues…
There are the errors:
Motorized_Fader:67:17: error: expected constructor, destructor, or type conversion before ‘(’ token
Motorized_Fader:68:17: error: expected constructor, destructor, or type conversion before ‘(’ token
Motorized_Fader:69:1: error: expected declaration before ‘}’ token
exit status 1
‘calibrateFader’ was not declared in this scope
I not just want you guys to fixe the code, I want to understand this error first of all.
I hope you guys can help me!!!
Motorized_Fader.ino (6.75 KB)
   MIDI.begin(MIDI_CHANNEL_OMNI); //Receive messages on all MIDI channels
   MIDI.turnThruOff(); //We don't need MIDI through for this
   pinMode (motorUp, OUTPUT);
   pinMode (motorDown, OUTPUT);
   calibrateFader();
   //}  // stray }
   attachInterrupt(0, nextChannel, RISING);
   attachInterrupt(1, prevChannel, RISING);
The stray curly bracket put the attachInterrupts outside of any function.
I can't compile the code. Missing libraries.
* Copyright © 2016. Guerau Pasola, Adrian Salvador
* We only updated the code to make it work on 2016, library dependencies
* have changed their API since 2012, all credits for the code goes to:
* Copyright © 2012. Cody Hazelwood.
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program. If not, see <http://www.gnu.org/licenses/>.
* Platform: Arduino Uno
* Description: MIDI controller using a motorized fader and an Arduino
* Dependencies: Capacitive Sensor Arduino Library (for fader touch sensitivity)
* http://playground.arduino.cc/Main/CapacitiveSensor
* MIDI Library for Arduino
* http://www.arduino.cc/playground/Main/MIDILibrary
 * Currently known issues:
 * * Only DAW Channels 1-8 work right now
 * * Better Fader Calibration is needed
 * * Doesn't work with Pro Tools due to Avid's restrictions (but any
 * other DAW that supports Mackie Control without HUI support will
 * work fine (Cubase, Logic, Digital Performer, Live, etc.)
#include <CapacitiveSensor.h> //Library for fader touch sensitivity
#include <MIDI.h> //Library for receiving MIDI messages
MIDI_CREATE_DEFAULT_INSTANCE();
#define PitchBend 0xE0
//Arduino Pin Assignments
const int motorDown = 5; //H-Bridge control to make the motor go down
const int motorUp = 6; //H-Bridge control to make the motor go up
//Inputs
const int wiper = 0; //Position of fader relative to GND (Analog 0)
const int touchSend = 7; //Send pin for Capacitance Sensing Circuit (Digital 7)
const int touchReceive = 8; //Receive pin for Capacitance Sensing Circuit (Digital 8)
//Variables
double faderMax = 0; //Value read by fader's maximum position (0-1023)
double faderMin = 0; //Value read by fader's minimum position (0-1023)
int faderChannel = 1; //Value from 1-8
bool touched = false; //Is the fader currently being touched?
bool positionUpdated = false; //Since touching, has the MIDI position been updated?
CapacitiveSensor touchLine = CapacitiveSensor(touchSend, touchReceive);
 calibrateFader();
 /* If there is a MIDI message waiting, and it is for the currently selected
 fader, and it is a PitchBend message (used for fader control), then convert
 the PitchBend value and update the fader's current position. */
 if (MIDI.read() && MIDI.getChannel() == faderChannel && MIDI.getType() == PitchBend ) {
 /* Bitwise math to take two 7 bit values for the PitchBend and convert to
 a single 14 bit value. Then converts it to value between 0 and 1023
 to control the fader. */
 int value = (((MIDI.getData2() << 7) + MIDI.getData1()) * 0.0625);
 updateFader(value);
 checkTouch(); //Checks to see if the fader is being touched
 //If the fader has been touched, it needs to update the position on the MIDI host
 if (!positionUpdated) {
 updateFaderMidi();
 positionUpdated = true;
void updateFaderMidi() {
 int velocity = faderPosition();
 byte channelData = 0xE0 + (faderChannel - 1);
 // MIDI Message:
 Serial.write(channelData); // E(PitchBend) Channel (0-9)
 Serial.write(velocity & 0x7F); // Least Sig Bits of Data
 Serial.write((velocity >> 7) & 0x7F); // Most Sig Bits of Data
//Check to see if the fader is being touched
void checkTouch() {
 //For the capacitiveSensor comparison below,
 //700 is arbitrary and may need to be changed
 //depending on the fader cap used (if any).
 if (!touched && touchLine.capacitiveSensor(30) >= 700) {
 touched = true;
 //Send MIDI Touch On Message
 Serial.write(0x90);
 Serial.write(0x67 + faderChannel);
 Serial.write(0x7f);
 else if (touched && touchLine.capacitiveSensor(30) < 700) {
 touched = false;
 //Send MIDI Touch Off Message
 Serial.write(0x90);
 Serial.write((byte) 0x00);
 if (touched) {
//Function to move fader to a specific position between 0-1023 if it's not already there
void updateFader(int position) {
 if (position < analogRead(wiper) - 10 && position > faderMin && !touched) {
 digitalWrite(motorDown, HIGH);
 while (position < analogRead(wiper) - 10 && !touched) {}; //Loops until motor is done moving
 digitalWrite(motorDown, LOW);
 else if (position > analogRead(wiper) + 10 && position < faderMax && !touched) {
 digitalWrite(motorUp, HIGH);
 while (position > analogRead(wiper) + 10 && !touched) {}; //Loops until motor is done moving
 digitalWrite(motorUp, LOW);
//Selects the next channel in the DAW
void nextChannel() {
 static unsigned long last_interrupt0_time = 0; //Interrupt Debouncing
 unsigned long interrupt0_time = millis(); //Interrupt Debouncing
 if (interrupt0_time - last_interrupt0_time > 200) { //Interrupt Debouncing
 if (faderChannel < 8) {
 faderChannel++;
 Serial.write(0x90);
 Serial.write(0x17 + faderChannel);
 Serial.write(0x7f); //Note On
 Serial.write(0x90);
 Serial.write((byte) 0x00); //Note Off
 last_interrupt0_time = interrupt0_time; //Interrupt Debouncing
//Selects the previous channel in the DAW
void prevChannel() {
 static unsigned long last_interrupt1_time = 0; //Interrupt Debouncing
 unsigned long interrupt1_time = millis(); //Interrupt Debouncing
 if (interrupt1_time - last_interrupt1_time > 200) { //Interrupt Debouncing
 if (faderChannel > 1) {
 faderChannel--;
 Serial.write(0x90);
 Serial.write(0x90);
 last_interrupt1_time = interrupt1_time; //Interrupt Debouncing
Thank you for the quick Reply, but i still with the exact same error problem...
It can be a Librarie Issue?
Where did you find the code?
(please don't say Instructables)
Maybe the answer is there.
I found it there:
The guy made a remake with the new libraries...
The original code from Cody Hazelwood:
https://blog.codyhazelwood.me/midi-control-with-an-arduino-and-a-motorized-fader/
I found a copy in this PDF file:
It compiled without errors or warnings.
//Inputs
//Variables
  calibrateFader();
    updateFader(value);
    updateFaderMidi();
  // MIDI Message:
//Calibrates the min and max position of the fader
void calibrateFader()
  //Send fader to the top and read max position
  delay(250);
  faderMax = analogRead(wiper) - 5;
  //Send fader to the bottom and read min position
  delay(250);
  faderMin = analogRead(wiper) + 5;
//Returns a MIDI pitch bend value for the fader's current position
//Cases ensure that there is a -infinity (min) and max value despite possible math error
int faderPosition()
  int position = analogRead(wiper);
  int returnValue = 0;
  if (position <= faderMin)
    returnValue = 0;
  else if (position >= faderMax)
    returnValue = 16383;
    returnValue = ((float)(position - faderMin) / (faderMax - faderMin)) * 16383;
  return returnValue;
void checkTouch()
    touched = true;
    Serial.write(0x90);
    Serial.write(0x7f);
    touched = false;
    Serial.write(0x90);
  if (touched)
void nextChannel()
  if (interrupt0_time - last_interrupt0_time > 200)   //Interrupt Debouncing
      faderChannel++;
      Serial.write(0x90);
      Serial.write(0x90);
void prevChannel()
  if (interrupt1_time - last_interrupt1_time > 200)   //Interrupt Debouncing
      faderChannel--;
      Serial.write(0x90);
      Serial.write(0x90);
That GitHub code has a calibrateFader function.
Post the latest code and the error. We can’t fix code that we can’t see.
