I have been building an 8 head peristaltic dosing pump system for some months now, and have used the below linked circuit (x8). I did add a 1k resistor between digital pins and base of each transistor for safety and omitted the pushbutton as I plan to instruct the unit via a network connection. The circuit works fine, but I am now trying to locate some sketch material so I can accurately calibrate the thing. I'd like to add a pushbutton to a breadboard and wire it so the Arduino can count off time between button presses while also turning a digital pin on and off. So when I press button, motor spins and millis() counts. When a measurable amount of fluid has been pumped into a measuring cup, the button is ticked again and the motor stops spinning and the millis() count is printed to serial. I could then use those numbers to define how many milliseconds it takes to produce 1 ml of fluid, and from there can update my project sketch and add the 8 head unit into my currently running hydroponics controller.
Any assistance, study leads, sketch snippets or just any information that can get me closer to my solution is appreciated in advance!
myggle:
Just on a point of terminology, pins are not "on" or "off", they're "high" or "low". Whether the "high" turns your device "on" or "off" is a different thing (and I know, is probably what you meant )
But consider an LED with the anode on a digital pin, cathode to ground. Then indeed, a "high" will turn the led "on". But if the anode was to 5V and the cathode on the i/o pin, then the led will be "on" when the pin is "low".
@756E6C, Thanks for the sketch, though I am unable to produce a favorable result from the pump and serial monitor. When in the loop, the motor spins endlessly and nothing is counted in the serial monitor. I wired the button according to the above linked tutorial (TIP120).
Prior to reading your sketch, I made a sketch of my own that also does not work, but hopefully it conveys my intentions and what I'm hoping to do. I want the arduino to acknowledge a button press that Writes a value of 255 to a pin and begins counting milliseconds. When the button is pressed again or depressed, that respective pin is set to 0 and the counter stops counting and prints the total amount of milliseconds to the serial monitor.
int button = 30; // Button connected to digital 30 with a 10k pulldown resistor to GND
int pump = 9; // pump on digital pin 9
unsigned long currentMillis = 0; // stores the value of millis()
unsigned long previousMillis = 0; // will store last time the LED was updated
unsigned long totalMillis = 0;
//========== THE SETUP ==============================
Serial.begin(9600); //default comm speed between arduino and serial monitor. no need to change.
pinMode(button, INPUT);
pinMode(pump, OUTPUT);
//========== THE LOOP ==============================
if (digitalRead(button) == HIGH)
previousMillis = millis(); // capture the beginning value of millis()
analogWrite(pump, 255);
else if (digitalRead(button) == LOW)
currentMillis = millis(); // capture the ending value of millis()
analogWrite(pump, 0);
totalMillis = currentMillis - previousMillis;
Serial.println(totalMillis);
delay(2000);
