I would like to calibrate an accelerometer so that I can get the output in meters per second. The math works when I stick my own numbers in there, but when I tell it to calibrate, it gets stuck in a loop. This is the piece of code that gets stuck in a loop:
void Calibrate(){
Calibrating = true;
while(Calibrating){ //Flash LED while Calibrating
if(millis() - previousMillis >= blinkInterval){
previousMillis = millis();
if(digitalRead(CalLED) == LOW){
digitalWrite(CalLED, HIGH);
else{
digitalWrite(CalLED, LOW);
for(Level = false; Level == true;){
if(yAverage == xAverage){
Level = true;
readAcceleration();
kAccel = (zAverage - yAverage);
zeroAccel = yAverage;
timeSeconds = 0;
Calibrating = false;
The bottom half after the led flash is supposed to check of it's level, and if it is, take those values to calculate the acceleration. It seems to be getting stuck in that for loop, even though there are plenty of occasions where x and y are equal. It is possible for x and y to be equal if it's tilted 45 degrees between x and y, so if there's a better way to calibrate it I'd like to see it. Also it seems that the z axis has a different zero point than the x and y axis, but that's another issue. The main point is that I want to fix this for loop.
Here's the full code:
* Pins used:
* Analog: 0, 1, 2
* Digital: 0, 1, 5, 6, 7, 8, 10, 11, 12, 13
* Pins available:
* Analog: 3, 4, 5, 6, 7
* Digital: 2, 3, 4, 9
#include <SD.h> //SD card library
#include <SPI.h>
boolean Calibrating = false; //Check if it's calibrating
boolean Level; //Chech if it's level
const int xAxis = A0; //Define axis inputs
const int yAxis = A1;
const int zAxis = A2;
const int CS_pin = 10; //Chip select for SD module
const int reCal = 9; //Button pin to recalibrate
const int CalLED = 8; //Pin to indicate calibratrion
const int samples = 100; //Define sampe size
const long blinkInterval = 40; //How fast the Indicators blink
const float G = 9.81;
long xTotal; //Store total values
long yTotal;
long zTotal;
int xAverage; //Store average values
int yAverage;
int zAverage;
int zeroAccel = 492; //Zero acceleration default
float xAccel; //Acceleration
float yAccel;
float zAccel;
float kAccel = 118; //Constant for calculating acceleration default
String dataString; //String to be stored on the SD card
String values; //Data string for serial output
unsigned long dataID = 1; //DataID to keep track of the data
unsigned long previousMillis = 0; //Timer mark
float timeSeconds; //Time elapsed since calibration
float fractional = 1000; //Divide milliseconds to seconds
SD.begin(); //Initialize SD library
Serial.begin(9600); //Initialize serial monitor
Serial.println("Initializing");
pinMode(xAxis, INPUT); //Set inputs
pinMode(yAxis, INPUT);
pinMode(zAxis, INPUT);
pinMode(reCal, INPUT); //Recalibrate button
pinMode(CalLED, OUTPUT); //Indicates Calibrating
digitalWrite(CalLED, LOW); //Not calibrating
analogReference(EXTERNAL); //3.3v ref for accelerometer output
for(int i = 0; i < samples; i++){ //Allow input to stablalize
analogRead(xAxis);
analogRead(yAxis);
analogRead(zAxis);
if(!SD.begin(CS_pin)) { //SD card stuff
Serial.println("Card Error");
return; //Comment out to test without the SD card
Serial.println("Card Ready");
File Data = SD.open("Data.csv", FILE_WRITE);
if(Data) {
Data.println(", , , , , , , , , , , , ");
String header = "Data ID, Seconds, X Axis, Y Axis, Z Axis";
Data.println (header);
Data.close();
else {
Serial.println("Couln't Open Data File");
return;
Serial.println("Calibrating Axis"); //Initial Calibration
Calibrate();
if(digitalRead(reCal) == HIGH){
Calibrate();
readAcceleration();
timeSeconds = millis()/fractional;
//Organize averages into a string, save, and println
values = String(dataID) + ", " + String(timeSeconds) + ", " + String(xAverage) + ", " + String(yAverage) + ", " + String(zAverage) + ", " + String(xAccel) + ", " + String(yAccel) + ", " + String(zAccel);
Serial.println(values);
dataString = String(dataID)+ String(timeSeconds) + ", " + String(xAccel) + ", " + String(yAccel) + ", " + String(zAccel);
Data.println(dataString);
Data.close();
dataID++;
void Calibrate(){
Calibrating = true;
else{
Level = true;
readAcceleration();
timeSeconds = 0;
void readAcceleration(){
for(int i = 0; i < samples; i++){ //Loop 10x
xTotal = xTotal + analogRead(xAxis); //Read each axis and incrament total
yTotal = yTotal + analogRead(yAxis);
zTotal = zTotal + analogRead(zAxis);
xAverage = xTotal / samples; //Calculate averages
yAverage = yTotal / samples;
zAverage = zTotal / samples;
xTotal = 0; //Reset totals
yTotal = 0;
zTotal = 0;
xAccel = G * (xAverage - zeroAccel)/kAccel;
yAccel = G * (yAverage - zeroAccel)/kAccel;
zAccel = G * (zAverage - zeroAccel)/kAccel;
