This is an unhelpful and arumengtative reply. You don't like resistor ladders. That's fine. That's your opinion and you are entitled to it. That does not make it gospel for everyone else.
@soonerdave, that was not my intention, I'm sorry if it turned out that way. I am using the freedom on this forum which is not a question-answer forum, but also to give direction, background information, alternative solutions and so on. I hope @TomGeorge does not mind that I made a little fun of his reply.
To be serious: You know now that there is discussion about the resistor ladder with buttons. It is up to you to decide if the risks are acceptable. If someday a problem occurs with the resistor-ladder and buttons, then you already know the weak points and perhaps you can fix it quickly.
I am considering both IR and Bluetooth solutions. I've done some experimentaton with the resistor ladder and while I see how it can work, I'm concerned about frequent reading and possible variability from analogRead.
I have looked into charlieplexing for diodes and buttons and while I get that concept, I think the need to do the scanning among the buttons may be a problem for some of the projects I have in mind that may be timing/looping-sensitive. Thanks.
It's your picnic, so you get to decide what kinda sandwiches to bring! Mmm… sandwiches.
For anyone following along who is hearing about this for the first time I am compelled to say
Finding which if any button is pressed on a matrix keyboard should not take significantly more time, nor that much more code, than using the resistor ladder idea or for that matter 9 buttons each on an input pin.
I'm not sure what "frequent reading" might have to do with it, but it is not a concern that analogRead may vary, but that the buttons may degrade over time.
I moved away from the button solution and implemented a Bluetooth communication module via an Android controller app. Works fantastically and it was reasonably simple to implement.
