I am trying to compile a code that will calibrate and read a Honeywell load cell (model 31). I'm using a breadboard setup with a INA125P amplified and Arduino due. Below are the error codes I am receiving and the calibration code itself.
Potentiometer: In function 'void loop()'
Potentiometer:17: error: 'Lb' was not declared in this scope
Serial.print(Lb);
Potentiometer:18: error: 'calibration_factor' was not declared in this scope
Serial.print(calibration_factor);
Potentiometer:24: warning: unused variable 'temp'
char temp = Serial.read();
Potentiometer:25: error: 'temp' was not declared in this scope
if(temp == '+')
Below is the calibration code I am trying to run but am having trouble.
int sensorValue = analogRead(A0);
// initialize serial communication at 9600 bits per second:
// read the input on analog pin 0:
Serial.print(analogRead(A0));
Serial.print(Lb);
// print out the value you read:
Serial.println(sensorValue);
I do not find Lb defined in the snippet of code you posted. Would it be too much trouble to fix the errors in your code first, before worrying about the calibration code?
The output from reading a load cell is usually an int. Did you write the program or just copy part of the program and miss the part that defines the variables?
Paul
I have also tried to define the variable but just receive more errors. Maybe I just don't quite know what I'm doing. Again I'm a complete beginner to coding.
If you are so new to coding, how did you manage with the first program? Perhaps you should start over with that program. Have you tried using the load cell example programs? Do they work?
Paul
I got lucky with the two other programs. Yes, Iv tried other load cell example programs. Most of them are written for a Arduino Nano. They did not work. So far iv worked out a couple of the error codes. Iv narrowed it down to the ones below.
Potentiometer: In function 'void loop()':
Potentiometer:25: warning: unused variable 'temp'
Potentiometer:26: error: 'temp' was not declared in this scope
if(temp == '+')
Find C++ documentation and review what "scope" means. When a variable is defined within a function, it BELONGS to that function and can be used in NO other function. It will disappear when that function ends.
Paul
I worked out the errors but I am not getting a serial monitor reading. The code is below,
int Lb = 0;
int calibration_factor = 100000;
Serial.print ("Reading: ");
Serial.print("Lb");
Serial.print("calibration_factor ");
Serial.print(sensorValue);
// delay in between reads for stability
Unless you put the sensorValue=analogRead(A0); in a code function that will be executed, you will not get anything in sensorValue.
Make it the same as where you print the value returned by analogRead.
More over, the value you are getting is a only a number, it is NOT pounds. You have to compute that.
Paul
