Calibration of weight scale on ESP32 from phone over BLE
Hi all!
I'm pretty new around programming even though I did some small projects with Arduino. Now I'm trying to make a program for getting data from the ESP32 over BLE based on two different sketches, one for the scale with HX711_ADC and other for RX/TX data from the phone over BLE.
Using both programs separately work fine so I tried to implement both into the same program and this is the result:
  • ESP32 advertisement
  • Connect to ESP32 on my phone with nRF Connect
    -=== Calibration from Monitor Serial (only from my PC)======= -> This I need to do it from the App
  • Start receiving data on the App and also on my Monitor Serial
I can send all kind of data from the App to the ESP32 and I see it on the Monitor Serial but I'm dying trying to understand why the commands I sent from my phone do not calibrate the scale, any help would be more than welcome, Thanks!!
Code:
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
int txValue = 0;
#define SERVICE_UUID           "6E400001-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
#define LED_BUILTIN 2
class MyServerCallbacks: public BLEServerCallbacks {
     void onConnect(BLEServer* pServer) {
     deviceConnected = true;
     void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
  void onWrite(BLECharacteristic *pCharacteristic) {
    std::string rxValue = pCharacteristic->getValue();
    if (rxValue.length() > 0) {
      Serial.println("=====START=RECEIVE=====");
      Serial.print("Received Value from App: ");
      for (int i = 0; i < rxValue.length(); i++) {
        Serial.print(rxValue[i]);
      //Do stuff based on the command received from the app
      if (rxValue.find("1") != -1) {
        Serial.println("Turning ON!");
        digitalWrite(LED_BUILTIN, HIGH);
     else if (rxValue.find("0") != -1) {
        Serial.println("Turning OFF!");
        digitalWrite(LED_BUILTIN, LOW);
      Serial.println("=====END=RECEIVED=====");
#include <HX711_ADC.h>
#include <EEPROM.h>
//HX711 constructor (dout pin, sck pin):
HX711_ADC LoadCell(26, 25);
int eepromAdress = 0;
long t;
void calibrate() {
  Serial.println("***");
  Serial.println("Start calibration:");
  Serial.println("It is assumed that the mcu was started with no load applied to the load cell.");
  Serial.println("Now, place your known mass on the loadcell,");
  Serial.println("then send the weight of this mass (i.e. 100.0) from serial monitor.");
  float m = 0;
  boolean f = 0;
  while (f == 0) {
    LoadCell.update();
    if (Serial.available() > 0) {
      m = Serial.parseFloat();
      if (m != 0) {
        Serial.print("Known mass is: ");
        Serial.println(m);
        f = 1;
      else {
        Serial.println("Invalid value");
  float c = LoadCell.getData() / m;
  LoadCell.setCalFactor(c);
  Serial.print("Calculated calibration value is: ");
  Serial.print(c);
  Serial.println(", use this in your project sketch");
  f = 0;
  Serial.print("Save this value to EEPROM adress ");
  Serial.print(eepromAdress);
  Serial.println("? y/n");
  while (f == 0) {
      char inByte = Serial.read();
      if (inByte == 'y') {
        #if defined(ESP8266)
        EEPROM.begin(512);
        #endif
        EEPROM.put(eepromAdress, c);
        EEPROM.commit();
        #endif
        EEPROM.get(eepromAdress, c);
        Serial.print("Value ");
        Serial.print(c);
        Serial.print(" saved to EEPROM address: ");
        Serial.println(eepromAdress);
        f = 1;
      else if (inByte == 'n') {
        Serial.println("Value not saved to EEPROM");
        f = 1;
  Serial.println("End calibration");
  Serial.println("For manual edit, send 'c' from serial monitor");
void changeSavedCalFactor() {
  float c = LoadCell.getCalFactor();
  boolean f = 0;
  Serial.print("Current value is: ");
  Serial.println(c);
  Serial.println("Now, send the new value from serial monitor, i.e. 696.0");
  while (f == 0) {
      c = Serial.parseFloat();
      if (c != 0) {
        Serial.print("New calibration value is: ");
        Serial.println(c);
        f = 1;
      else {
        Serial.println("Invalid value, exit");
        return;
  f = 0;
  while (f == 0) {
        EEPROM.begin(512);
        #endif
        EEPROM.commit();
        #endif
        Serial.print(c);
        f = 1;
        f = 1;
  Serial.println("End change calibration value");
  //Create the BLE device
  BLEDevice::init("ESP32");
  //Set pinmode for the builting led (weight)
  pinMode(LED_BUILTIN, OUTPUT);
  //Create the BLE Server
  BLEServer *pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  //Create the BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  //Create a BLE Characteristic
  pCharacteristic = pService->createCharacteristic(
                    CHARACTERISTIC_UUID_TX,
                    BLECharacteristic::PROPERTY_NOTIFY
  //BLE2902 needed to notify
  pCharacteristic->addDescriptor(new BLE2902());
  //Characteristic for the receiving end
  BLECharacteristic *pCharacteristic = pService->createCharacteristic(
                                      CHARACTERISTIC_UUID_RX,
                                      BLECharacteristic::PROPERTY_WRITE
  pCharacteristic->setCallbacks(new MyCallbacks());
  //Start the Service
  pService->start();
  //Start advertising
  pServer->getAdvertising()->start();
  Serial.println("Waiting for a client connection to notify...");
  delay(10);
  Serial.println("Starting...");
  LoadCell.begin();
  long stabilisingtime = 2000; // tare preciscion can be improved by adding a few seconds of stabilising time
  LoadCell.start(stabilisingtime);
  if (LoadCell.getTareTimeoutFlag()) {
    Serial.println("Tare timeout, check MCU>HX711 wiring and pin designations");
  else {
    LoadCell.setCalFactor(1.0); // user set calibration value (float)
    Serial.println("Startup + tare is complete");
  while (!LoadCell.update());
  calibrate();
  //update() should be called at least as often as HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS
  //longer delay in sketch will reduce effective sample rate (be carefull with delay() in the loop)
  LoadCell.update();
  //get smoothed value from the data set
  if (deviceConnected) {
    txValue = LoadCell.getData();
    //Conversion of txValue
    char txString[8];
    dtostrf(txValue, 1, 2, txString);
    //Setting the value to the characteristic
    pCharacteristic->setValue(txString);
    //Notifying the connected client
    pCharacteristic->notify();
    Serial.println("Sent value: " + String(txString));
    delay(50);
  //receive from serial terminal
    float i;
    if (inByte == 't') LoadCell.tareNoDelay();
    else if (inByte == 'c') changeSavedCalFactor();
  //check if last tare operation is complete
  if (LoadCell.getTareStatus() == true) {
    Serial.println("Tare complete");
Could be because I'm sending string but my function reads only floats??
float m = 0;
  boolean f = 0;
  while (f == 0) {
    LoadCell.update();
