Calibration on MPU6050 and ADXL377 accelerometers
Hi everyone.
I'm working on a "flight computer" that is intended to be embedded inside a model rocket. I use an Arduino Nano that reads acceleration values on a MPU6050 and an ADXL377.
Everything works quite well but I have no idea of what both outputs mean. The MPU6050 has several sensivity levels but I use the DMP algorythms (the example in the sensor library) so I don't know which level is used (+-2/4/8/16 g).
The ADXL377 (up to 200g) outputs analog values so I need to shock the sensor in order to cause a known acceleration but I have no idea how to proceed. (I have a 3D printer if it could help)
Thank you by advance for your time !
The MPU6050 can be verified using gravity. I can't think of a simple way to validate the readings from a 200g sensor, except reading 1g gravity, but if you can do that there is no reason to think that your higher readings during a flight would be wrong.
In fact the DMP sketch cannot output raw acceleration, it only outputs acceleration with gravity removed.
I'm assuming the DMP sketch sets the MPU to +-4g but I can only speculate about it. However I think that assuming that the ADXL is linear : a (g) = (ADXLreading-500) / 2.5 seems to work.
Kivatch:
The fifo Buffer we get from the mpu6050 DMP has the following values
 | Default MotionApps v2.0 42-byte FIFO packet structure:                                           |
 | [QUAT W][      ][QUAT X][      ][QUAT Y][      ][QUAT Z][      ][GYRO X][      ][GYRO Y][      ] |
 |   0   1   2   3   4   5   6   7   8   9  10  11  12  13  14  15  16  17  18  19  20  21  22  23  |
 | [GYRO Z][      ][ACC X ][      ][ACC Y ][      ][ACC Z ][      ][      ]                         |
 |  24  25  26  27  28  29  30  31  32  33  34  35  36  37  38  39  40  41
Accelerometer and gyro readings are present along with the quaternion
Z
Thank you !
