I have a color sensor experiment. how do I calibrate the tcs3200 sensor to match the rgb standard and the program code?
I have tried using red, green, blue, black and white color paper. but it can't match the standard example on red (255,145,169) should be (255,0,0).
#include <Wire.h>
// TCS3200 color sensor wiring
#define S0 2
#define S1 3
#define S2 4
#define S3 5
#define sensorOut 6
#define LED 7
pinMode(S0, OUTPUT);
pinMode(S1, OUTPUT);
pinMode(S2, OUTPUT);
pinMode(S3, OUTPUT);
pinMode(sensorOut, INPUT);
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH);
// Setting frequency-scaling to 20%
digitalWrite(S0, HIGH);
digitalWrite(S1, LOW);
Serial.begin(9600); // use the serial port to print out the resultant data
readTCS3200();
// Function to read data from TCS3200 sensor
void readTCS3200() {
// Calibration values
int redMin = 50, redMax = 346;
int greenMin = 85, greenMax = 348;
int blueMin = 40, blueMax = 262;
int clearMin = 0, clearMax = 500;
int redPW, greenPW, bluePW, clearPW;
int redValue, greenValue, blueValue, clearValue;
const unsigned long timeout = 1000000; // 1 second timeout for pulseIn
// Read Red Pulse Width
digitalWrite(S2, LOW);
digitalWrite(S3, LOW);
redPW = pulseIn(sensorOut, LOW, timeout);
redValue = map(redPW, redMin, redMax, 255, 0);
Serial.print("Raw Red: "); Serial.print(redPW);
Serial.print(" Mapped Red: "); Serial.println(redValue);
// Read Green Pulse Width
digitalWrite(S2, HIGH);
digitalWrite(S3, HIGH);
greenPW = pulseIn(sensorOut, LOW, timeout);
greenValue = map(greenPW, greenMin, greenMax, 255, 0);
Serial.print("Raw Green: "); Serial.print(greenPW);
Serial.print(" Mapped Green: "); Serial.println(greenValue);
// Read Blue Pulse Width
bluePW = pulseIn(sensorOut, LOW, timeout);
blueValue = map(bluePW, blueMin, blueMax, 255, 0);
Serial.print("Raw Blue: "); Serial.print(bluePW);
Serial.print(" Mapped Blue: "); Serial.println(blueValue);
// Read Clear Pulse Width
clearPW = pulseIn(sensorOut, LOW, timeout);
clearValue = map(clearPW, clearMin, clearMax, 255, 0);
Serial.print("Raw Clear: "); Serial.print(clearPW);
Serial.print(" Mapped Clear: "); Serial.println(clearValue);
