Call callback function of object in class
Hey guys,
I hope I can describe my problem understandable... :confused: I just made my first tries with callback functions and in an own class-example I made it work:
class c{
  public:
  float i(int data, int (* cbFunction)(int)) {
    return cbFunction(data);
int func(int var) {
  return var*3;
c c;
  Serial.println(c.i(5,&func)); // use "func" as callback function to call from c.i() --> works!
This was my first step to my actual target: Using a callback function that's a method within an object. Background: I created my own "framework" for my automatic plant care.
Now I came to the point that one sensor (DHT11) has its own library which simplifies the usage of the sensor. But of course I still need my own framework for all the other sensors and controls.
So this is the code to use the DHT11 sensor:
#include "DHT.h" //DHT Bibliothek laden
#define DHTPIN 2 //Der Sensor wird an PIN 2 angeschlossen
#define DHTTYPE DHT11    // Es handelt sich um den DHT22 Sensor
DHT dht(DHTPIN, DHTTYPE); //Der Sensor wird ab jetzt mit „dth“ angesprochen
  dht.begin(); //DHT22 Sensor starten
  delay(2000);
  float Luftfeuchtigkeit = dht.readHumidity(); //die Luftfeuchtigkeit auslesen und unter „Luftfeutchtigkeit“ speichern
  float Temperatur = dht.readTemperature();//die Temperatur auslesen und unter „Temperatur“ speichern
  Serial.print("Luftfeuchtigkeit: "); //Im seriellen Monitor den Text und
  Serial.print(Luftfeuchtigkeit); //die Dazugehörigen Werte anzeigen
  Serial.println(" %");
  Serial.print("Temperatur: ");
  Serial.print(Temperatur);
  Serial.println(" Grad Celsius");
Of course that works properly, too.
Now the problematic step:
How can I call the method dht.readTemperature(); as callback from c.i()? Or rather how can I pass this callback to c.i()
I really appreciate every hint and help, because what I tried didn't work....
Thanks and regards!
class c{
  using FMPtr = float (DHT::*)(); //type aliasing: FMPtr is a member function of class DHT which returns a float and take no argument.
  public:
  float i(int data, DHT& Obj, FMPtr Ptr) {
    return (Obj.*Ptr)(); //invoking the member function
DHT dht(DHTPIN, DHTTYPE); //Der Sensor wird ab jetzt mit „dth" angesprochen
   c ClassC;
   ClassC.i(data, dht, dht.readTemperature);
For more information: Standard C++
Thanks for your code! Since I do not understand everything I have a lot to learn. :slight_smile:
But your code throws an error message I can’t fix, could you please help me again?
class c{
  public:
   c ClassC;
   ClassC.i(1, dht, dht.readTemperature); // THIS LINE THROWS THE ERROR MESSAGE
Arduino: 1.8.11 (Mac OS X), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/Volumes/Daten/username/Documents/Nextcloud/Programmierung/Arduino/callback_function_dht11/callback_function_dht11.ino: In function 'void setup()':
callback_function_dht11:22:40: error: invalid use of non-static member function 'float DHT::readTemperature(bool, bool)'
In file included from /Volumes/Daten/username/Documents/Nextcloud/Programmierung/Arduino/callback_function_dht11/callback_function_dht11.ino:1:0:
/Volumes/Daten/username/Documents/Nextcloud/Programmierung/Arduino/libraries/DHT_sensor_library/DHT.h:51:10: note: declared here
    float readTemperature(bool S=false, bool force=false);
exit status 1
Replace:
with
using FMPtr = float (DHT::*)(bool, bool);
throws this error message
/Volumes/Daten/username/Documents/Nextcloud/Programmierung/Arduino/callback_function_dht11/callback_function_dht11.ino: In member function 'float c::i(int, DHT&, c::FMPtr)':
callback_function_dht11:9:23: error: too few arguments to function
exit status 1
so I replaced it with
return (Obj.*Ptr)(false, false); //invoking the member function
to have the correct number of arguments. Then the following error message is shown
exit status 1
Did you replace the type aliasing, FMPtr?
Also try add a &:
ClassC.i(1, dht, &(dht.readTemperature));
arduino_new:
I did.
arduino_new:
Also try add a &:
I did and it compiles without errors now. I will try to use and implement it, thanks for your help so far. I hope I don’t need to come back, but let’s see… ;D
