Win 7 X64 PRO AMD platform
Added URL to IDE 1.8.0.
Shut down IDE and restart.
Unplugged 101.
RE- plugged 101.
Went to Boards, Board Manager, nothing listed in UPDATABLE.
Selected 101 as board and set appropriate COM. (8 in my case)
Set bare minimum sketch as the one to upload.
Compiled first as a check no problem.
Set VERBOSE for upload.
Hit the UPLOAD button.
Arduino: 1.8.0 (Windows 7), Board: "Arduino/Genuino 101"
Sketch uses 17168 bytes (11%) of program storage space. Maximum is 155648 bytes.
Forcing reset using 1200bps open/close on port COM8
d:\Users\Bob\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28/arduino101load/arduino101load d:\Users\Bob\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28/x86/bin d:\Users\Bob\AppData\Local\Temp\arduino_build_567021/sketch_dec24a.ino.bin COM8 verbose ATP1BLE000-1541C5635 141312
Starting download script...
Args to shell: [d:\Users\Bob\AppData\Local\Arduino15\packages\Intel\tools\arduino101load\1.6.9+1.28/x86/bin d:\Users\Bob\AppData\Local\Temp\arduino_build_567021/sketch_dec24a.ino.bin COM8 verbose ATP1BLE000-1541C5635 141312]
Serial Port: COM8
BIN FILE d:\Users\Bob\AppData\Local\Temp\arduino_build_567021/sketch_dec24a.ino.bin
Waiting for device...
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Try again but hit Master reset
Serial Port: COM8
Device found!
Verifying BLE version: ATP1BLE000-1541C5635
BLE version: verified
Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release!!!
can't detach
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2016 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
ID 8087:0aba
Run-time device DFU version 0011
Claiming USB DFU Interface...
Setting Alternate Setting #7 ...
Determining device status: state = dfuDNLOAD-IDLE, status = 0
aborting previous incomplete transfer
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0011
Device returned transfer size 2048
Copying data from PC to DFU device
Download [ ] 0% 0 bytes
Download [== ] 10% 2048 bytes
Download [===== ] 21% 4096 bytes
Download [======= ] 31% 6144 bytes
Download [========== ] 42% 8192 bytes
Download [============= ] 53% 10240 bytes
Download [=============== ] 63% 12288 bytes
Download [================== ] 74% 14336 bytes
Download [===================== ] 85% 16384 bytes
Download [======================= ] 95% 17168 bytes
Download [=========================] 100% 17168 bytes
Download done.
Sent a total of 17168 bytes
state(2) = dfuIDLE, status(0) = No error condition is present
Done!
Resetting USB to switch back to runtime mode
SUCCESS: Sketch will execute in about 5 seconds.
Select 101 firmware updater as programmer.
Hit Burn Bootloader
Hit RESET on board as per lower console instruction. (If this should be MASTER RESET then the text in the IDE needs updating)
d:\Users\Bob\AppData\Local\Arduino15\packages\Intel\tools\flashpack\1.0.0/flash_dfu.bat
Reset the board before proceeding...
find: sensor: No such file or directory
Error while burning bootloader.
Try again but used MASTER RESET.
Eventual timeout as per above.
Boards manager lists the Curie as 1.0.7
Upload BLINK example to re-check board works basic.
