Call function (char input)
before void setup() I defined 'char t[3];'
This is the piece of the code I want to put inside a specific function..
if (flag) {
  screen.setTextSize(5);
  screen.text(t, 50, 40);
  flag=!flag;
if (currentMillis - previousMillis > interval) {
       screen.background(250, 250, 250);
       flag = !flag;
I want to make a funtion outside the loop to call whenever I need to! I want to create something like:
CalcVal(t); - when I call this function it will input the char 't' inside the screen text definition... I know how to do it when using int or float, but I have never done this with a char. How can this be solved?
Thanks, António
Try it and see what happens. Report any problems here and get help if necessary. What type of variable is the first argument to the screen.text() function ?
A string, I guess!
amlo13: A string, I guess!
Don't guess. Go look.
Ok, thanks :slight_smile:
If the variable is declared as global (which seems to be the case) it will be accessible in the function without needing to be passed to it.
...R
