Call function from an array
Hello everyone,
is it some how possible to call funktion from an array?
What i want to do is a Systemcheck depending on some events which happens. These events write data in an Array
char* syscheck[] = {"Timer" , "Sensor"};
syscheck now has the names of the funkctions which should be called.
Do i have to check every entry per hand and when it is in the array call the function "per hand" or can i somehow do a call direktly?
CL
PS my english is bad, so sorry for it :~
Yes, you can have an array of function pointers, but these are not the same as strings.
Example of function pointer array:
Thanks for the quick answers,
i tried to work as the exaple shows, but always get
invalid conversion from 'void ()() to 'void'
when i try compiling it with arduino
Chaos_Lord: Thanks for the quick answers,
There were multiple examples, so without seeing the exact code you are using and what line that refers to, it's a bit difficult to say...
