Hi every one.
The code below got error of ''
what's that means?
Thanks
adam
#include <Wire.h>
#define I2C_Freq 100000
#define SDA_0 21
#define SCL_0 22
#define SDA_1 18
#define SCL_1 19
TwoWire I2C_0 = TwoWire(0);
TwoWire I2C_1 = TwoWire(1);
I2C_0.begin(SDA_0 , SCL_0 , I2C_Freq );
I2C_1.begin(SDA_1 , SCL_1 , I2C_Freq );
`Preformatted text`
Arduino: 1.8.16 (Windows 7), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, Huge APP (3MB No OTA/1MB SPIFFS), 80MHz, None"
C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_jun05e\sketch_jun05e.ino: In function 'void setup()':
sketch_jun05e:16:40: error: call of overloaded 'begin(int, int, int)' is ambiguous
In file included from C:\Users\HUA.DELLV-PC\Documents\Arduino\sketch_jun05e\sketch_jun05e.ino:1:
C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.h:79:10: note: candidate: 'bool TwoWire::begin(int, int, uint32_t)'
bool begin(int sda=-1, int scl=-1, uint32_t frequency=0); // returns true, if successful init of i2c bus
C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.3\libraries\Wire\src/Wire.h:80:10: note: candidate: 'bool TwoWire::begin(uint8_t, int, int, uint32_t)'
bool begin(uint8_t slaveAddr, int sda=-1, int scl=-1, uint32_t frequency=0);
sketch_jun05e:17:40: error: call of overloaded 'begin(int, int, int)' is ambiguous
exit status 1
option enabled in File -> Preferences.
