Call of Overloaded "println(float(&)(int)) is ambiguous
Hi everyone, thanks in advance for the help.
I am trying to create a function that I can call in a different program that converts an analog reading to a voltage.
Here is my code:
int vpin=A0;
Serial.println(vbattery);
float vbattery (int vpin){
float vactual;
vactual=((analogRead(vpin))/1023)*5;
return vactual;
What exactly is going wrong?
Thanks.
vbattery is a function but here you are treating it as a variable. It needs to be called with an integer as a parameter, in this case the pin number from which to read the analogue input. So the call will be something like
Serial.println(vbattery(A0));
And here:
You're taking the result of an analogRead, which is an integer between 0 and 1023, and integer dividing it by 1023. then dividing that by 5, which will return 0 for any value returned by analogRead other than 1023, which will result in 5. Probably not what you want...
That line should be:
vactual=(float)analogRead(vpin) * 5.0 / 1023.0;
Regards,
Ray L.
