Call of overloaded write is ambigious
Hi All,
I'm new to Arduino and am trying to build a simple datalogger for temperature and write the sensor data with date and time to a log file on a SD card. I'm getting an error "
exit status 1 call of overloaded 'write(uint8_t, int)' is ambiguous" trying to compile my code.
While searching for a solution, I've found that it appears while switching from SD.h to SDfat.h, the way to pass parameters to file.write (SDFat.h) is different than from logfile.print (SD.h).
I just can't figure out what I'm doing wrong....
void logData() {
  int val;
  double temp;
  val=analogRead(0);
  temp=Thermistor(val);
  DateTime now;
  now = RTC.now();
  file.write(now.day(), DEC);
  file.write("/");
  file.write(now.month(), DEC);
  file.write("/");
  file.write(now.year(), DEC);
  file.write(",");
  file.write(now.hour(), DEC);
  file.write(":");
  file.write(now.minute(), DEC);
  file.write(":");
  file.write(now.second(), DEC);
  file.write(",");
  file.write(temp);
  file.println();
DateTime now;
backwoodsjack: DateTime now;
Datetime is a public class in RTClib.h It can hold the date and time from an DS1307 realtime clock.
write doesn't work like that. write is for sending raw bytes. If you want to send something in a human readable format use print instead. And you don't need the DEC as that will be the default.
file.print(now.day());
Succes!! Thank you Delta_G!
is file.write() for binary files and file.print for text files ?
peterj1978: Succes!! Thank you Delta_G!
Sort of like that, write is to send raw bytes and print is for sending something as ascii characters.
