I am trying to reduce the footprint of my globals in my project and while messing around found 2 very strange behaviors. Yes this program is contrived, it's for illustrative purposes, and I wanted to make certain that the compiler wasn't optimizing away the msg variable.
the msg variable below is obviously local, but when I include the call to sprintf() it apparently is moved to the global space:
pinMode(1, OUTPUT);
pinMode(2, INPUT);
digitalWrite(1, f1());
bool f1() {
char msg[100] = "1234";
if (digitalRead(1))
msg[0] = '1';
msg[0] = '0';
// when included: Global variables use 117 bytes (5%) of dynamic memory
// when excluded: Global variables use 13 bytes (0%) of dynamic memory
sprintf(msg, "%d", 1);
int i;
if (msg[0]) {
return true;
return false;
2.The second weird thing I noticed is when msg is initialized to a length of <= 3 chars, it's local, but when initialized to > 3 chars, it apparently is moved to the global space:
pinMode(1, OUTPUT);
pinMode(2, INPUT);
bool f1() {
// Global variables use 17 bytes (0%) of dynamic memory
// char msg[100] = "123";
// Global variables use 117 bytes (5%) of dynamic memory
if (digitalRead(1))
msg[0] = '1';
msg[0] = '0';
int i;
if (msg[0]) {
return true;
return false;
Ok, it looks like sprintf() is allocating room in the global space for internal use as well as string constants passed to it. If I could move those constants to the program space, that would be great, but the F() macro doesn't work ...
void setup() {}
f1();
bool f1() {
sprintf(msg, "test A %d", 1); // Including only this line: Global variables use 119 bytes (5%) of dynamic memory
sprintf(msg, "test A %d", 1); // Including this and above: no change
sprintf(msg, "test B %d", 1); // Including this and above: Global variables use 129 bytes (6%) of dynamic memory
This problem is not specific to sprintf. If you don't use sprintf, the compiler optimizes out the char array.
If you look at the compiler output, you'll see that the compiler allocates 100 bytes in static memory, and 100 bytes on the stack. Then it copies the 5 first characters from the static string to the local array, and finally, it fills the rest of the local array with zeros. The 95 zero bytes in static memory are never used.
Different compilers seem to behave completely differently, AVR GCC 4.5.4 doesn't include the 95 zero bytes, for example.
It could be a bug in GCC, might be worth opening a ticket. If you do so, please post the link here.
