I'm writing a sketch to control a BLDC motor from HD.
The circuit is already up and running.
(http://www.c2o.pro.br/en/automation/download/BLDC_controller_4_wires_II.png)
Now I want to optimize the code to increase speed.
I want a program to receive commands from PC (start and stop) through the serial port to control the motor drive.
I Implemented a while loop in the start () function to control the motor:
void start() {
while(running) {
stepping(1);
delay(steppingDelay);
stepping(2);
stepping(3);
if (steppingDelay > 4) {
steppingDelay = steppingDelay - 1;
checkSerial();
Is there any way to make the update of the boolean variable "running" without to call the function "checkSerial" at the end of each while loop?
Some callback function to be called "only" when there is a complete message in serial.
Thanks for the tips.
Markos
PS-
void checkSerial() {
if (Serial.available() > 0) {
for (int i = 0; i < 7; i++) {
message = 0;
delay(6);*
length_message = Serial.available();*
if (length_message >= 7) {*
Serial.print("message larger than the limit (7 characters)!");*
Serial.println(length_message);*
for (int i = 0; i < length_message; i++) {*
c = Serial.read();*
} else {*
c = Serial.read();*
if (c != '\n' && c != '\r') {*
_ message = c;_
* length = strlen(message);*
* message[length] = '\0'; // message[length] = 0*
* if ( (strcmp(message, "START") == 0) || (strcmp(message, "start") == 0) ) {*
* Serial.println("Starting");*
* running = true;*
* } else if (strcmp(message, "STOP") == 0 || strcmp(message, "stop") == 0) {*
* Serial.println("Stopping");*
* running = false;*
* } else {*
* Serial.print(message);*
* Serial.println(" - Unknown command!");*
