You simply tell a piece of code what function you want to use when it wants to do something. It just stores that function in a variable. And once the piece of code thinks it needs to use that function it can call it.
It's a bit like ISR on the Arduino with attachInterrupt() but it is not a ISR. That just stores the function name you pass it. And the real ISR calls that function (by reading the variable) when it's fired.
But every function can call a variable other function. And if it's used when a condition is met it's often called a call back
I know this is an old thread, but I'm just about to leap into a new project, and figured I'd expend my brain cells on the application logic... so I'm hoping someone might simplify what I need to do for the example below...
How do/would I setup the case where I create a class with a function that asynchronously receives serial input, and only when the incoming terminator (e.g. CR) is received, it raises a callback in the main program code.
i.e. minimal pseudocode...
myCLASS::tick() {
// do stuff
// receive serial chars to build a c-string
if (CR was received)
myCallback(data) // send the comnplete c-string back to the main program
main::loop() {
myclass->tick(); // tap the class frequently to maintin the input functionality
// do other stuff
main::myCallback(data) { // we get thrown here to process the call from myClass::tick() event
// process the complete returned c-string
lastchancename:
myCLASS::tick() {
// do stuff
main::loop() {
// do other stuff
Here you go:
class MyClass
using InputEvent = void (*)(const char*); //type aliasing
//C++ version of: typedef void (*InputEvent)(const char*)
public:
void RegisterCallback(InputEvent InEvent)
Event = InEvent;
void Tick()
//accumuate buffer here
if (true) {
//raise event
Event(buffer);
private:
InputEvent Event;
char buffer[10];
//global callback
void ProcessData(const char* Data)
Serial.println(Data);
MyClass MClass;
MClass.RegisterCallback(ProcessData);
MClass.Tick();
