Hello,
I'm currently doing an IoT project, which includes reading data from an NFC-tag (with a reader called PN532 from Elechouse). I would like to apply a callback function which could receive messages through mqtt, however after adding a line in the void loop() which reads NFC-tags, no callback messages get through.
void loop(void) {
// Maintain the MQTT connection
if (!client.connected()) {
reconnect1();
// Allow client to process incoming messages and maintain connection to server.
client.loop();
if(!client2.connected()) {
reconnect2();
client2.loop();
// Maintain the PN532 connection
while (!connected) {
connected = connect();
// Register an NFC-card
while (!firstCardRegistered){
acc_str_card += register_card();
firstCardRegistered = true;
// Buffer to store the UID
uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };
// UID size (4 or 7 bytes depending on card type)
uint8_t uidLength;
// The following lines wait for information from an NFC-tag.
cardRecognized = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
if (cardRecognized) {
std::string uidstr = ""; // The id of the NFC-tag in base 10.
for (uint8_t i = 0; i < uidLength; i++)
uidstr += std::to_string(uid[i]) + " ";
const char* uidcc = uidstr.c_str(); // MQTT accepts only string of the form "const char*"
// Turn security on or off
if (acc_str_card == uidcc){
Serial.println("Proper tag used!");
if (onOff == 0 ){
publishMessage(mqtt_topic, "Authenticated! System turned on!");
Serial.println("Authenticated! System turned on!");
setColor(0,255,0);
delay(3000);
onOff = 1;
publishMessage(mqtt_topic, "Authenticated! System turned off!");
Serial.println("Authenticated! System turned off!");
delay(3000);
onOff = 0;
Serial.println("False NFC-chip");
publishMessage(mqtt_topic, "False Nfc-Chip!");
delay(3000);
Serial.println("Waiting for card (ISO14443A Mifare)...");
Serial.println("");
, where the problematic line is
This line alone makes it impossible to receive callback messages. When it is not being used everything works normally. What could be the reason?
Library for NFC-tag reader:
elechouse/PN532: NFC library for Arduino using PN532 (github.com)
