I am having a problem with the last if statement in the main loop to follow through. The alarm function seems to be exiting prematurely. I am using a DS3231 RTC My confusion comes from the else if statement working perfectly. The LED flashes and the LCD flashes 'FEEDING' for a split second and the screen goes back to the main loop. I cannot get the alarm1 if condition to finish. Any help is greatly appreciated. Thanks
// include LCD library code
#include <LiquidCrystal.h>
// include Wire library code (needed for I2C protocol devices)
#include <Wire.h>
// include Stepper motor library code for rotarty output
#include <Stepper.h>
// Define number of steps per rotation:
const int stepsPerRevolution = 2048;
// Wiring:
// Pin to IN1 on the ULN2003 driver
// Pin to IN2 on the ULN2003 driver
// Pin to IN3 on the ULN2003 driver
// Pin to IN4 on the ULN2003 driver
// Create stepper object called 'myStepper', note the pin order:
Stepper myStepper = Stepper(stepsPerRevolution, 9, 11, 10, 12);
// LCD module connections (RS, E, D4, D5, D6, D7)
LiquidCrystal lcd(3, 4, 5, 6, 7, 8);
#define button1 A0
#define button2 A1
#define button3 A2
const int alarm_pin = 13; // Alarms pin number
// Set the stepper speed to 5 rpm:
myStepper.setSpeed(5);
pinMode(2, INPUT_PULLUP);
pinMode(A0, INPUT_PULLUP);
pinMode(A1, INPUT_PULLUP);
pinMode(A2, INPUT_PULLUP);
pinMode(13, OUTPUT);
digitalWrite(alarm_pin, LOW);
// set up the LCD's number of columns and rows
lcd.begin(16, 2);
Wire.begin(); // Join i2c bus
attachInterrupt(digitalPinToInterrupt(2), Alarm, FALLING);
// Variables declaration
bool alarm1_status, alarm2_status;
char Time[] = " : ",
calendar[] = " / /20 ",
alarm1[] = " : ", alarm2[] = " : ";
byte i, second, minute, hour, day, date, month, year,
alarm1_minute, alarm1_hour, alarm2_minute, alarm2_hour,
status_reg;
void Alarm(){
digitalWrite(alarm_pin, HIGH);
lcd.setCursor(0,1);
lcd.print("FEEDING");
myStepper.step(2);
delay(5000);
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("FED");
delay(55000);
void DS3231_read(){ // Function to read time & calendar data
Wire.beginTransmission(0x68); // Start I2C protocol with DS3231 address
Wire.write(0); // Send register address
Wire.endTransmission(false); // I2C restart
Wire.requestFrom(0x68, 7); // Request 7 bytes from DS3231 and release I2C bus at end of reading
second = Wire.read(); // Read seconds from register 0
minute = Wire.read(); // Read minuts from register 1
hour = Wire.read(); // Read hour from register 2
day = Wire.read(); // Read day from register 3
date = Wire.read(); // Read date from register 4
month = Wire.read(); // Read month from register 5
year = Wire.read(); // Read year from register 6
void alarms_read_display(){ // Function to read and display alarm1, alarm2 and temperature data
byte control_reg, temperature_lsb;
char temperature_msb;
Wire.write(0x08); // Send register address
Wire.requestFrom(0x68, 11); // Request 11 bytes from DS3231 and release I2C bus at end of reading
alarm1_minute = Wire.read(); // Read alarm1 minutes
alarm1_hour = Wire.read(); // Read alarm1 hours
Wire.read(); // Skip alarm1 day/date register
alarm2_minute = Wire.read(); // Read alarm2 minutes
alarm2_hour = Wire.read(); // Read alarm2 hours
Wire.read(); // Skip alarm2 day/date register
control_reg = Wire.read(); // Read the DS3231 control register
status_reg = Wire.read(); // Read the DS3231 status register
Wire.read(); // Skip aging offset register
// Convert BCD to decimal
alarm1_minute = (alarm1_minute >> 4) * 10 + (alarm1_minute & 0x0F);
alarm1_hour = (alarm1_hour >> 4) * 10 + (alarm1_hour & 0x0F);
alarm2_minute = (alarm2_minute >> 4) * 10 + (alarm2_minute & 0x0F);
alarm2_hour = (alarm2_hour >> 4) * 10 + (alarm2_hour & 0x0F);
// End conversion
alarm1[8] = alarm1_minute % 10 + 48;
alarm1[7] = alarm1_minute / 10 + 48;
alarm1[5] = alarm1_hour % 10 + 48;
alarm1[4] = alarm1_hour / 10 + 48;
alarm2[8] = alarm2_minute % 10 + 48;
alarm2[7] = alarm2_minute / 10 + 48;
alarm2[5] = alarm2_hour % 10 + 48;
alarm2[4] = alarm2_hour / 10 + 48;
alarm1_status = bitRead(control_reg, 0); // Read alarm1 interrupt enable bit (A1IE) from DS3231 control register
alarm2_status = bitRead(control_reg, 1); // Read alarm2 interrupt enable bit (A2IE) from DS3231 control register
lcd.setCursor(0, 1);
lcd.print(" : : ");
if(alarm1_hour < 10){ lcd.setCursor(0, 1);
lcd.print("0");
lcd.setCursor(1,1);
lcd.print(alarm1_hour);
else lcd.print(alarm1_hour);
lcd.setCursor(3, 1);
if(alarm1_minute < 10){ lcd.setCursor(3, 1);
lcd.print("0");
lcd.setCursor(4,1);
lcd.print(alarm1_minute);
else lcd.print(alarm1_minute);
lcd.setCursor(5, 1);
if(alarm1_status == 1) lcd.print("ON ");
else lcd.print("OFF");
lcd.setCursor(8, 1);
if(alarm2_hour < 10){ lcd.setCursor(8, 1);
lcd.print("0");
lcd.setCursor(9,1);
lcd.print(alarm2_hour);
else lcd.print(alarm2_hour);
lcd.setCursor(11, 1);
if(alarm2_minute < 10){ lcd.setCursor(11, 1);
lcd.print("0");
lcd.setCursor(12,1);
lcd.print(alarm2_minute);
else lcd.print(alarm2_minute);
lcd.setCursor(13, 1);
if(alarm2_status == 1) lcd.print("ON ");
void calendar_display(){ // Function to display calendar
switch(day){
case 1: strcpy(calendar, "Sun / /20 "); break;
case 2: strcpy(calendar, "Mon / /20 "); break;
case 3: strcpy(calendar, "Tue / /20 "); break;
case 4: strcpy(calendar, "Wed / /20 "); break;
case 5: strcpy(calendar, "Thu / /20 "); break;
case 6: strcpy(calendar, "Fri / /20 "); break;
case 7: strcpy(calendar, "Sat / /20 "); break;
default: strcpy(calendar, "Sat / /20 ");
calendar[13] = year % 10 + 48;
calendar[12] = year / 10 + 48;
calendar[8] = month % 10 + 48;
calendar[7] = month / 10 + 48;
calendar[5] = date % 10 + 48;
calendar[4] = date / 10 + 48;
lcd.setCursor( 7, 0);
lcd.print(calendar); // Display calendar
void DS3231_display(){
second = (second >> 4) * 10 + (second & 0x0F);
minute = (minute >> 4) * 10 + (minute & 0x0F);
hour = (hour >> 4) * 10 + (hour & 0x0F);
date = (date >> 4) * 10 + (date & 0x0F);
month = (month >> 4) * 10 + (month & 0x0F);
year = (year >> 4) * 10 + (year & 0x0F);
// End conversion
Time[7] = second % 10 + 48;
Time[6] = second / 10 + 48;
Time[4] = minute % 10 + 48;
Time[3] = minute / 10 + 48;
Time[1] = hour % 10 + 48;
Time[0] = hour / 10 + 48;
calendar_display(); // Call calendar display function
lcd.setCursor(0, 0);
lcd.print(Time); // Display time
void Blink(){
byte j = 0;
while(j < 10 && (digitalRead(button1) || i >= 5) && digitalRead(button2) && (digitalRead(button3) || i < 5)){
j++;
delay(25);
byte edit(byte x, byte y, byte parameter){
char text[3];
while(!digitalRead(button1) || !digitalRead(button3)); // Wait until button B1 is released
while(true){
while(!digitalRead(button2)){ // If button B2 is pressed
parameter++;
if(((i == 0) || (i == 5)) && parameter > 23) // If hours > 23 ==> hours = 0
parameter = 0;
if(((i == 1) || (i == 6)) && parameter > 59) // If minutes > 59 ==> minutes = 0
parameter = 0;
if(i == 2 && parameter > 31) // If date > 31 ==> date = 1
parameter = 1;
if(i == 3 && parameter > 12) // If month > 12 ==> month = 1
parameter = 1;
if(i == 4 && parameter > 99) // If year > 99 ==> year = 0
parameter = 0;
if(i == 7 && parameter > 1) // For alarms ON or OFF (1: alarm ON, 0: alarm OFF)
parameter = 0;
lcd.setCursor(x, y);
if(i == 7){ // For alarms ON & OFF
if(parameter == 1) lcd.print("ON ");
else{
sprintf(text,"%02u", parameter);
lcd.print(text);
if(i >= 5){
DS3231_read(); // Read data from DS3231
DS3231_display(); // Display DS3231 time and calendar
delay(200); // Wait 200ms
lcd.print(" "); // Print two spaces
if(i == 7) lcd.print(" "); // Print space (for alarms ON & OFF)
Blink(); // Call Blink function
else{
lcd.print(text);
Blink();
if(i >= 5){
DS3231_read();
DS3231_display();}
if((!digitalRead(button1) && i < 5) || (!digitalRead(button3) && i >= 5)){
i++; // Increment 'i' for the next parameter
return parameter; // Return parameter value and exit
if(!digitalRead(button1)){ // If B1 button is pressed
i = 0;
hour = edit(0, 0, hour);
minute = edit(3, 0, minute);
while(!digitalRead(button1)); // Wait until button B1 released
while(true){
while(!digitalRead(button2)){ // If button B2 button is pressed
day++; // Increment day
if(day > 7) day = 1;
calendar_display(); // Call display_calendar function
delay(200);
lcd.print(" "); // Print 3 spaces
Blink();
lcd.print(calendar); // Print calendar
if(!digitalRead(button1)) // If button B1 is pressed
date = edit(4, 1, date); // Edit date
month = edit(7, 1, month); // Edit month
year = edit(12, 1, year); // Edit year
// Convert decimal to BCD
minute = ((minute / 10) << 4) + (minute % 10);
hour = ((hour / 10) << 4) + (hour % 10);
date = ((date / 10) << 4) + (date % 10);
month = ((month / 10) << 4) + (month % 10);
year = ((year / 10) << 4) + (year % 10);
// End conversion
// Write time & calendar data to DS3231 RTC
Wire.write(0); // Reset sesonds and start oscillator
Wire.write(minute); // Write minute
Wire.write(hour); // Write hour
Wire.write(day); // Write day
Wire.write(date); // Write date
Wire.write(month); // Write month
Wire.write(year); // Write year
Wire.endTransmission(); // Stop transmission and release the I2C bus
delay(200);
if(!digitalRead(button3)){ // If B3 button is pressed
while(!digitalRead(button3)); // Wait until button B3 released
i = 5;
lcd.print(" : : ");
alarm1_hour = edit(0, 1, alarm1_hour);
alarm1_minute = edit(3, 1, alarm1_minute);
alarm1_status = edit(5, 1, alarm1_status);
i = 5;
alarm2_hour = edit(8, 1, alarm2_hour);
alarm2_minute = edit(11, 1, alarm2_minute);
alarm2_status = edit(13, 1, alarm2_status);
alarm1_minute = ((alarm1_minute / 10) << 4) + (alarm1_minute % 10);
alarm1_hour = ((alarm1_hour / 10) << 4) + (alarm1_hour % 10);
alarm2_minute = ((alarm2_minute / 10) << 4) + (alarm2_minute % 10);
alarm2_hour = ((alarm2_hour / 10) << 4) + (alarm2_hour % 10);
// Write alarms data to DS3231
Wire.write(7); // Send register address (alarm1 seconds)
Wire.write(0); // Write 0 to alarm1 seconds
Wire.write(alarm1_minute); // Write alarm1 minutes value to DS3231
Wire.write(alarm1_hour); // Write alarm1 hours value to DS3231
Wire.write(0x80); // Alarm1 when hours, minutes, and seconds match
Wire.write(alarm2_minute); // Write alarm2 minutes value to DS3231
Wire.write(alarm2_hour); // Write alarm2 hours value to DS3231
Wire.write(0x80); // Alarm2 when hours and minutes match
Wire.write(4 | alarm1_status | (alarm2_status << 1)); // Write data to DS3231 control register (enable interrupt when alarm)
Wire.write(0); // Clear alarm flag bits
// End conversion
alarm1_status = bitRead(control_reg, 1); // Read alarm1 interrupt enable bit (A1IE) from DS3231 control register
DS3231_read(); // Read time and calendar parameters from DS3231 RTC
alarms_read_display(); // Read and display alarms parameters
DS3231_display(); // Display time & calendar
if ( Time[0,1] == alarm1[4,5] && Time[3,4] == alarm1[7,8] && alarm1_status == 1){ //Compare current time with Alarm time and run alarm
Alarm();
else if( Time[0,1] == alarm2[4,5] && Time[3,4] == alarm2[7,8] && alarm2_status == 1){ //Compare current time with Alarm time and run alarm **WORKS**
lcd.setCursor(8,1);
myStepper.step(2);
delay(5000);
lcd.setCursor(8,1);
lcd.print(" ");
lcd.setCursor(8,1);
lcd.print("FED");
delay(55000);
else{
delay(50); //Delay 50ms
