I want to use a timer interrupt and I want my ISR to look something like this:
void ISR()
count++;
if(count == 500)
callFunction();
Is this possible?
void ISR()
count++;
if(count == 500)
callFunction();
Is this possible?
Is it possible?
Yes.
Will it work as expected?
Depends on the function called.
Is it sensible for non-trivial functions?
Very rarely.
Whandall:
Is it possible?Yes.
Very rarely.
Thank you for the quick reply! I shall post on this thread if I get further doubts!
General advice when using interrupts is that the interrupt servicing code should do as little as possible - say set a flag or something similarly small.
Your non-interrupt code should act when that flag is set, which probably means you need to avoid using delay.
abhir24:
I want to use a timer interrupt and I want my ISR to look something like this:void ISR()
count++;
if(count == 500)
callFunction();
Is this possible?
Don't do that if callFunction() could possibly take more than a few hundred microseconds.
boolean DoTheCall = false;
void ISR() {
count++;
if (count == 500) {
DoTheCall = true;
count = 0; // Did you forget this or is count reset somewhere else?
if (DoTheCall) {
callFunction();
DoTheCall = false;
johnwasser:
I worked on the code in the evening after work and I came up with a very similar solution like your's, John. Thank you for the help, nevertheless.
wildbill:
General advice when using interrupts is that the interrupt servicing code should do as little as possible - say set a flag or something similarly small.Your non-interrupt code should act when that flag is set, which probably means you need to avoid using delay.
I used the ISR only to set a flag and then later polled that flag in the loop(). Worked great! Thank you!
