Calling a function that has similar variables as the parent function
I've noticed that when I execute the following print_payload function, the Arduino crashes and locks up completely
void print_payload(byte * payload)
 char buf[16];
 lcd.clear();
 sprintf(buf, "RX: %d%d%d", payload[0], payload[1], payload[2]);
 lcd.setCursor(0,1);
 lcd.print(buf);
 print_prompt();
void print_prompt()
  const char * msg = "WAITING...";
  char buf[16];
  sprintf(buf, "%16s", msg);
  lcd.setCursor(0,1);
  lcd.print(buf);
I had a hunch that the freezing type behaviour was to do with the buf variable so I changed the char buf[16] variable in print_prompt to char buf1[16] and the freezing behaviour stopped and the code executed normally.
Could anyone explain why I encountered the freezing? I thought the variable space for the two functions should have been separate?
Any help appreciated,
Andy
How and where is the payload array declared ?
  char buf[16];
  lcd.setCursor(0,1);
  lcd.print(buf);
This is plain silly.
No need to copy any data anywhere.
  lcd.setCursor(0,1);
  lcd.print(msg);
The 16 character string and the terminating NULL will not fit in a 16 element array. The string you are specifying is not 16 characters, so the %16s should just be %s.
And, you should be using snprintf(), to make CERTAIN that you don't overflow the array.
Loop code where payload is loaded
         byte buf [10]={0};
          byte received = recvMsg (fAvailable, fRead, buf, sizeof (buf));
          if (received)
				/*lcd.clear();
				for(int x=0; x<5; x++)
					lcd.print(buf[x], HEX);
				lcd.setCursor(0,1);
					lcd.print(buf[x+5], HEX);
				if((buf[0] == 0x2B) && (buf[6] == 0x2D))
					lcd.clear();
					lcd.print("HERE");
					delay(3000);
					lcd.clear();
					byte adr = buf[1];
					byte cmd = buf[2];
					byte payload[3] = {buf[3], buf[4], buf[5]};
					print_payload(payload);
The purpose of the ‘silly’ sprintf(buf, “%16s”, msg); is to left pad with spaces so the message is displayed on the right hand side of the LCD as opposed to left
Thanks,
Andy
The purpose of the 'silly' sprintf(buf, "%16s", msg); is to left pad with spaces so the message is displayed on the right hand side of the LCD as opposed to left
You know the length of a line on the LCD. You know the number of characters to print.
Simple arithmetic would tell you the number of spaces to pad with, and a for loop to print that number of spaces would be far less code (and a lot more obvious).
Still, 16 + 1 is not 16 or less.
Thanks for the feedback paul. Ive modified the software as follows:
#include <Wire.h>
#include <LiquidCrystal_PCF8574.h>
#include <EEPROM_FIX.h>
#include <find_lcd.h>
#include <RS485_protocol.h>
#include "rs485_functions.h"
#define eeLCD 0
LiquidCrystal_PCF8574 lcd(EEPROM.read(eeLCD));
rs485_init();
lcd.begin(16, 2);
findLCD(eeLCD);
lcd.setBacklight(255);
print_prompt();
         byte buf [10]={0};
          if (received)
				/*lcd.clear();
				lcd.setCursor(0,1);
					lcd.clear();
					lcd.print("HERE");
					delay(3000);
					lcd.clear();
					byte adr = buf[1];
					byte cmd = buf[2];
					print_payload(payload, cmd);
void print_payload(byte * payload, byte cmd)
  lcd.print("Locker: ");
  for(int x=0; x<3; x++)
    lcd.print(payload[x]);
  lcd.setCursor(0,1);
  if(cmd){sprintf(buf, "%16s", "ON");}
  else{sprintf(buf, "%16s", "OFF");}
  print_prompt();
void print_prompt()
  lcd.clear();
  lcd.print("STATUS");
  lcd.setCursor(0,1);
  const char msg [] = "WAITING...";
  lcd_print_right(msg, sizeof(msg));
void lcd_print_right(char * msg, int msg_size)
  for(int x = 16-(msg_size-1); x--; x>0)
    lcd.print(" ");
  lcd.print(msg);
Please let me know if you have any other tips
Regarding the char buf[16] issue, do you think this was to do with the memory allocation for sprintf ?
Does that even compile?
  lcd.setCursor(0,1);
Where is that buf array defined? It needs to be at least 17 elements long, to hold 16 characters plus a terminating NULL.
It looks to me like lcd_print_right() needs to be used more, and sprintf() not at all.
