My code currently receives a OSC value into a variable and I'd like to call a function using that variable. For example, the osc message looks like this:
/dmx/set
and a value of say 0.5
The variable is set to the second part of the address 'set'. I now want to call the set() function and pass on the value of 0.5. How would I do this? I thought about using case switch, but it won't allow you to switch on a string type variable. Is there any way to do this?
You could use strcmp to match the function name from an array of names, then use the index in the switch statement.
If all the functions were of the same type, you could use a structure containing the name of the function, and a pointer to the function itself, when you get a match, you call the function via the pointer.
Lots of ways.
Hmm sounds like it may work. This is what I got so far:
//Is an OSC message available?
if ( osc.available() ) {
//this will be our variable that we want to call as a function. Possible values may be 'set' 'flash' 'tap' etc
char *var = recMes.getAddress(1);
//this is the value that we need to pass to the function
float value = (float)recMes.getArgFloat(0);
//How do I call the right function here????
void set(float value){
//do something
void flash(float value){
//do something
void tap(float value){
//do something
Sorry still a little new to some of these concepts. Thanks again!
