calling all experts - need a bit breaduino help...
so i think i followed all the directions exactly... but clearly i missed something :frowning:
can anyone tell from these pics what i did wrong?.. thanks guys!..
Confirm with a multimeter you are using the correct pins on the Reset switch?
Edit:
Confirm your 22pF capacitors go to each leg of the crystal?
maques_n_la:
Presumably it's not working as intended. What did you intend it to do? What does it actually do?
The two caps on each side of the crystal, you only have 1 correctly seated.
cjdelphi and LarryD nailed it!.. thanks guys!!!
