Calling Arduino subs from PC
Hello all!
I am back after more than 10 years. :slight_smile:
My first question:
I have code loaded into Arduino (mega). The code consists of many programs/sub programs, how do I start any of them from Arduino IDE (or later maybe from Delphi)?
Thanks,
Juha
You can upload only one program from the PC to the Arduino at a time.
i've used some form of the following code on all my projects to exercise functions using single character cmds entered thru the serial monitor. It captures a multidigit value preceeding the cmd to be used as an argument. Multiple arguments requiring capturing a value in a variable
// pcRead - debugging using serial monitor
const char version [] = "PcRead 240209a";
int debug = 0;
// process single character commands from the PC
#define MAX_CHAR  10
char s [MAX_CHAR] = {};
int  analogPin = 0;
void
pcRead (void)
    static int  val = 0;
    if (Serial.available()) {
        int c = Serial.read ();
        switch (c)  {
        case '0':
        case '1':
        case '2':
        case '3':
        case '4':
        case '5':
        case '6':
        case '7':
        case '8':
        case '9':
            val = c - '0' + (10 * val);
        case 'A':
            analogPin = val;
            Serial.print   ("analogPin = ");
            Serial.println (val);
            val = 0;
        case 'D':
            debug ^= 1;
        case 'I':
            pinMode (val, INPUT);
            Serial.print   ("pinMode ");
            Serial.print   (val);
            Serial.println (" INPUT");
            val = 0;
        case 'O':
            pinMode (val, OUTPUT);
            Serial.print   (val);
            Serial.println (" OUTPUT");
            val = 0;
        case 'P':
            pinMode (val, INPUT_PULLUP);
            Serial.print   (val);
            Serial.println (" INPUT_PULLUP");
            val = 0;
        case 'a':
            Serial.print   ("analogRead: ");
            Serial.println (analogRead (val));
            val = 0;
        case 'c':
            digitalWrite (val, LOW);
            Serial.print   ("digitalWrite: LOW  ");
            val = 0;
        case 'p':
#if !defined(ARDUINO_ARCH_ESP32)
            analogWrite (analogPin, val);
            Serial.print   ("analogWrite: pin ");
            Serial.print   (analogPin);
            Serial.print   (", ");
            val = 0;
#endif
        case 'r':
            Serial.print   ("digitalRead: pin ");
            Serial.print   (val);
            Serial.println (digitalRead (val));
            val = 0;
        case 's':
            digitalWrite (val, HIGH);
            Serial.print   ("digitalWrite: HIGH ");
            val = 0;
        case 't':
            Serial.print   ("pinToggle ");
            digitalWrite (val, ! digitalRead (val));
            val = 0;
        case 'v':
            Serial.print ("\nversion: ");
            Serial.println (version);
        case '\n':          // ignore
        case '?':
            Serial.println ("\npcRead:\n");
            Serial.println ("    [0-9] append to #");
            Serial.println ("  # A - set analog pin #");
            Serial.println ("  # D - set debug to #");
            Serial.println ("  # I - set pin # to INPUT");
            Serial.println ("  # O - set pin # to OUTPUT");
            Serial.println ("  # P - set pin # to INPUT_PULLUP");
            Serial.println ("  # a - analogRead (pin #)");
            Serial.println ("  # c - digitalWrite (pin #, LOW)");
            Serial.println ("  # p - analogWrite (analogPin, #)");
            Serial.println ("  # r - digitalRead (pin #)");
            Serial.println ("  # s  - digitalWrite (pin #, HIGH)");
            Serial.println ("    t  - toggle pin output");
            Serial.println ("    v  - print version");
            Serial.println ("    ?  - list of commands");
        default:
            Serial.print ("unknown char ");
            Serial.println (c,HEX);
void
loop (void)
    pcRead ();
void
setup (void)
#if defined(ARDUINO_ARCH_ESP32)
    Serial.println ("esp32");
#endif
Can you elaborate on that?
The mega is only going to contain the bootloader + whatever sketch you most recently uploaded.
@jremington I know you said
I wanted to clarify to @j_p_i that there can only be one sketch in the Arduino, because it was such an unusual question
In addition to the serial communication approach, if your device is WiFi-enabled, you could communicate with it over TCP or HTTP or even gRPC. (You could also do HTTP-over-serial or gRPC-over-serial.)
Or, if you close the serial monitor window, anything on the PC that can open a serial port and start talking at it.
If @j_p_i wants to use something that has a significant user base, documentation and examples, he might like
https://docs.arduino.cc/retired/hacking/software/FirmataLibrary/
a7
You're going to have to show the code. Don't forget to use code tags!
Did you write the code? That affects what questions may be asked.
Your code is exactly what I needed
Thanks a lot!
