Hi!
I am using an Arduino Nano in a project, part of which requires to PWM control a DC brush motor (through a transistor). Two keys control for control are connected to the two interrupt pins and their other terminals are connected to a digital pin. When I press the button, the motor should run for a certain time at certain speeds, then stop. I have written two interrupt handlers which basically set a flag whenever any of the keys is pressed, which is then detected in the main loop and reset when required.
The problem is, when the DC brush motor is operated at high power, it produces lots of electrical noise which generates interrupts on the keyboard handlers. To avoid these erroneous interrupts I am trying to disable interrupts in the main routine once the interrupt flag was set, and then re-enable them when motor is OFF.
However, I am witnessing a strange misbehavior: as soon as I call attachinterrupt() in the main code to re-enable interrupts, this generates an external interrupt and the handler is executed for the second time. I.e. when I push the button, the algorithm is executed twice. This happens exactly when attachinterrupt() is called: when I put a delay just before calling this function, the second (erroneous) run of the routine is delayed by the specified time period.
Please help me figure out how I can avoid this problem. I am attaching part of my code below (irrelevant parts trimmed):
/* Arduino keys
2 Int, Kbd1
3 Int, Kbd2
4 KbdCommon
5 PWM Fan
#define OFF 0
#define ON 1
unsigned long Tstart=0, currentmillis=0; // time=0,
// Tstart - the moment when the key was pressed
byte duration=5; // Motor operation in seconds
int seconds = 0; // number of seconds since the button was pushed
int count=0; // loop cycles counter
boolean state = OFF; // flag, if ON, the motor must be running
const byte FAN_PWM = 5; // Motor is connected to pin 5
const byte keyboardPin = 4; // common pin for the key buttons
const byte key1InterruptPin = 2; // key1 pin
const byte key2InterruptPin = 3; // key2 pin
const byte key1Interrupt = 0; // key1 attached to int0
const byte key2Interrupt = 1; // key1 attached to int0
byte currentFanPower=0;
void setFanPower (int power) {
if (power>255) power=255;
if (power<0) power=0;
analogWrite(FAN_PWM, power);
// Interrupt handler if Key 1 is pressed
void key1pressed (){
seconds = 0;
state = ON;
Tstart=millis(); // note the time when the key was pressed
// Interrupt handler if Key 2 is pressed (currently both keys doing the same)
void key2pressed (){
seconds = 0;
state = ON;
// initialize the keyboard
pinMode(keyboardPin, OUTPUT);
digitalWrite(keyboardPin, LOW); // connect the common pin for two buttons to ground
pinMode(key1InterruptPin, INPUT);
digitalWrite(key1InterruptPin, HIGH); // pull up
pinMode(key2InterruptPin, INPUT);
digitalWrite(key2InterruptPin, HIGH); // pull up
attachInterrupt(key1Interrupt, key1pressed, FALLING);
attachInterrupt(key2Interrupt, key2pressed, FALLING);
//initialize PWM pin
pinMode(FAN_PWM, OUTPUT);
analogWrite(FAN_PWM, 0);
if (state) {
detachInterrupt(key1Interrupt); // disable interrupts on key1
detachInterrupt(key2Interrupt); // disable interrupts on key2
currentmillis=millis();
seconds=(currentmillis-Tstart)/1000;
if (seconds<=duration){
currentFanPower=92; // set FAN power, 0...255 (92 = 18.5V)
state=OFF;
seconds=0;
currentFanPower=0; // Turn OFF the motor
attachInterrupt(key1Interrupt, key1pressed, FALLING); // re-enable interrupt on key1
attachInterrupt(key2Interrupt, key2pressed, FALLING); // re-enable interrupt on key1
setFanPower(currentFanPower); // enable actual PWM output on the pin
